Old 03-05-2013, 08:20 PM   #1
mwjames
mwjames's Avatar
steering shaft question
Has anyone ever tried to put a 1990's Jeep CHEROKEE STEERING SHAFT on a 92 GMC Sierra are any model. There is a video on youtube of a guy that say it is a direct fit. Reason I ask is my rag joint is going bad.
mwjames is offline   Reply With Quote
Old 03-06-2013, 10:55 PM   #2
bdiamond
Re: steering shaft question
Its sort of a direct fit. If its the same video I watched, the guy just telescoped it in by hand and bolted it up. Its not that easy. You need to burn out the energy absorbing pins then it'll bolt up...
bdiamond is offline   Reply With Quote
Old 03-07-2013, 12:13 AM   #3
mwjames
mwjames's Avatar
I tried it today, went to pull a part and found a 93 jeep cherokee steering shaft for $12.00 no mods was needed a direct fit. Made the truck ride a 100% better.
Old 03-07-2013, 02:01 AM   #4
Ziegelsteinfaust
What is the Cherokee shaft supposed to do?
Ziegelsteinfaust is offline   Reply With Quote
Old 03-07-2013, 09:50 AM   #5
mwjames
mwjames's Avatar
Cherokee has ujoints instead of a rag joint, which take away the play in the steering.
Old 03-07-2013, 09:53 AM   #6
andrewmp6
Its a common swap on the g body as well.
andrewmp6 is offline   Reply With Quote
