03-05-2013, 10:03 PM | #1 |
Brake booster question?????
I want to replace the original brake booster in my `67. I`ve never really been to happy with the power assist, seems a bit harder then it should be and looks crusty. I see 67-72 could have came with a "Bendix" booster, which is in my truck now. I also see 71-72 could have came with a "Delco Moraine" type.
I was wondering if one type feels better then another. Both are very reasonable to buy rebuilt. Or any other suggestions?
1967 GMC Suburban, Supercharged 6.2 LS with a 6l80e , my 11 second tow vehicle! *pic in my profile* 1987 GMC CrewCab Dually 6.0 LS/6L90e, new tow pig. http://67-72chevytrucks.com/gallery/...=74049&cat=500 |
03-05-2013, 10:09 PM | #2 |
Re: Brake booster question?????
1972 CHEVROLET C10 PICKUP : Brake/Wheel Hub : Power Brake Booster
A-1 CARDONE Part # 5471125 Reman. A-1 CARDONE Vacuum Booster with Delco Brake Booster; Original Delco Moraine Boosters Are Usually Gold-Anodized.; w/o Master Cylinder $62.79 A-1 CARDONE Part # 5473709 Reman. A-1 CARDONE Vacuum Booster with Bendix Brake Booster; Original Bendix Boosters are Usually Painted Black; w/o Master Cylinder $63.89
03-05-2013, 10:56 PM | #3 |
i went back to original but know some with even a smaler performace chromed boosters that no one says they see a difference though other than looks.
03-06-2013, 10:03 AM | #4 |
I am a Referee of life.
You should probably do a search.IIRC(and that is questionable) the boosters only work with the same brand MC.That's not a deal killer since MCs are inexpensive but something you need to research before starting the swap.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
03-06-2013, 08:03 PM | #5 |
Maybe the length of the rod might be different or the recess where it bolts. I think your right, it seems like there are choices on the masters, I will keep that in mind. Thanks
07-11-2013, 10:31 PM | #6 |
Not trying to hijack but I have legit booster question. Is there a difference in the distance between the studs for the monting brackets for a Delco and Bendix?
07-11-2013, 10:50 PM | #7 |
I've had both types and couldn't tell any difference in feel. Right now I have the Delco in place and intend to keep it.
Shawn 1970 Chevy C-10 SWB, 350, TKO 600 5 speed My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881 |
