AC Delete heater box
I found these ac delete boxes online and wondered if anybody has had any expeirence with them? I want to ditch the all the A/C stuff and clean up the firewall a little bit.
http://www.acdelete.com/pages/67-72_Truck.htm Thanks!!
'71 Chevy 3/4 Ton Longbed '22 Chevy Tahoe RST '67 Firebird- 8 sec street car '24 GMC CC 4x4 Duramax Dually |
Re: AC Delete heater box
i bought it , just need to install it. not looking forward to the heater core replacement at the same time.
Bought something similar a few years ago. Not sure if it is the same exactly. Mount holes for the cover was undersized needed re-drilled but fit was decent. You shouldn't need anything but the delete cover if your fan, core is good. Maybe some RTV for the seal.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
yeah i bought the whole kit, it came with the sealer, heater core, and all hardware. acdelete seems like a good company the parts seem quality .
when it warms up i will install it and post pics, should make my engine bay look alot better. |
Is this comparable to a factory non ac truck box? The way it bolts on
Posted via Mobile Device |
the boat guy
Seems like a lot of coin for something that most trucks came with from the factory. I have an extra one in the attic.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
Im kinda throwing the idea of using something like this to run vintage air through instead of shaving my firewall.
It's my understanding that a factory non a/c heater box wont fit on an a/c firewall. Someone correct me if I'm wrong...
You are correct, this kit eliminates the huge ac box and allows you to keep the heater and blower motor.
Cluster King
![]() Join Date: Nov 2012
Yes there are absolute differences in the A/C trucks and non A/C trucks. the firewall sheet metal is different. You cannot use a heater box from a non A/C truck and put it on a A/C firewall without having uncovered pass throughs.
The kit in the link fixes that problem and covers everything correctly. |
i just installed the acdelete.com kit on my truck, it was a pain in the butt and i would value it at about $100. live and learn but i could of saved some money and not bought this kit. i will say it does look much better than the huge factory ac box.
67-72 parts collector,…
![]() Join Date: Nov 2002
What part was the pain?^^^
#13 |
u have to mount the two pieces of fiberglass together then calk them, if it were one moulded piece of abs it would be better. then i took the hood hinge off to make installation
easier. |
