Old 03-06-2013, 01:16 AM   #1
3/4ton72heavychevy
3/4ton72heavychevy's Avatar
My lights are gone... Help please.
I've got a 72 chevy c20, and for the past few days my truck has been taking 4 or 5 seconds of cranking before it will start. The radio will flash on and off while the truck is idleing, but will stay on fine when I am driving. Sounded like the battery going bad to me. Until last night. I start the truck and my headlights come one, but my interior light, dash lights, and taillights will not turn on. Even when I am driving.
Any ideas on what the issue is? bad fuse maybe? any help is appreciated.
3/4ton72heavychevy is offline   Reply With Quote
Old 03-06-2013, 01:50 AM   #2
Scott>72-GMC
Scott>72-GMC's Avatar
Re: My lights are gone... Help please.
Grounds can always be an issue little sandpaper usually helps
72 GMC super custom.
Scott>72-GMC is offline   Reply With Quote
Old 03-06-2013, 04:16 AM   #3
b.eddy's72
b.eddy's72's Avatar
I second the grounds. Also check the wires on the back of the alt and the plug on the regulator if it still has the external one
72 Chevy LB, LS in the works, 4L80, Grandfather bought it brand new.
66 GMC Short Step, 84 Front Suspension, many more mods to come
67 Chevy 3/4 Ton, 327, Auto, Factory A/C
Ya must have been movin cause I was haulin a*$ when I passed you
b.eddy's72 is offline   Reply With Quote
Old 03-06-2013, 07:04 AM   #4
piecesparts
Parts and more parts
piecesparts's Avatar
I would get a test probe and follow out the different circuits for power and see if they are energized. If that is true, then I would support the ground discussion. Something is definitely loose and it is giving you sparodic results. Start at your battery and check all of you connections from it. That would include the power cable from the battery to the solenoid on your starter. If it is loose, then you would have the results that you speak of. I had a Pontiac GTo that did just what yousaid and it was a loose battery cable
Frank
piecesparts is offline   Reply With Quote
Old 03-06-2013, 07:20 AM   #5
cdowns
cdowns's Avatar
with electrical problems here is a hint// lookin and staring at a connection with a squint and a stern look does no good// taking the connection apart and cleaning that connection helps electricity flow
Old 03-06-2013, 09:08 AM   #6
midniteblues
midniteblues's Avatar
comeon that works sometimes
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline   Reply With Quote
Old 03-06-2013, 09:16 AM   #7
dapperg
dapperg's Avatar
Glad I found this post. Sounds like I have a similar issue. I'm still troubleshooting it. http://67-72chevytrucks.com/vboard/s...d.php?t=569212
. . . . . . . . . ________ . . . . . .
__________///____ //_____
/____ 72’ __/_____ /_ ___/
===( o )=======( o )
72' Chevy C10 Super Fleetside Longbed
"Speak softly & carry a big pistol."
dapperg is offline   Reply With Quote
Old 03-06-2013, 10:26 AM   #8
68gmsee
Active Member
68gmsee's Avatar
Leave it to cdowns...
I agree with above re. grounds also. Road grime and rust on mounting bolts no longer have path to battery negative. After you check the wiring, go to the parts store and pick up a handful of ground straps. Place them so that the truck components (cab, frame, radiator support, engine) make a clean, complete circuit back to battery.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 03-06-2013, 10:38 AM   #9
3/4ton72heavychevy
I've gone over and over it all and seems like theyre all good. And the odd thing, my reverse lights and my turn signals still work. My only other thought is that monday night, I replaced my tailgate and rear bumper since I had them off to paint the bed a while back. maybe I messed something up back by the lights when I did that. We shall see.
Old 03-06-2013, 10:54 AM   #10
dapperg
dapperg's Avatar
Yeah my occured after I was messing with my ignition. My signals and inside floor light works but my bed light and dash lights are out totally.
Old 03-06-2013, 09:48 PM   #11
3/4ton72heavychevy
Twas a couple blown fuses, thanks yall.
Old 03-06-2013, 09:50 PM   #12
dapperg
dapperg's Avatar
Mine was ground wires under the hood.. glad I read this post, thanks!
Old 03-06-2013, 10:21 PM   #13
buckskins4ever
buckskins4ever's Avatar
mine did similar...I can tell you that since a new light switch for our trucks is like $20 it is worth its weight in gold to replace. Found a short in the switch itself
buckskins4ever is offline   Reply With Quote
