Old 03-06-2013, 10:38 AM   #1
BionicABs1
Need some rear end help quick if possible
I have a truck that is stamped TDE0827-K. There are 12 bolts in this rear end however is does not look like a typical GM 12 bolt according to the mechanic working on it. Can anyone help de code what this rear end is?
BionicABs1 is offline   Reply With Quote
Old 03-06-2013, 12:15 PM   #2
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: Need some rear end help quick if possible
Stock original rear end?
If it's stock original... It's a 12 bolt truck rear end. Maybe your mechanic has only seen car 12-bolts. There are subtle differences.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 03-06-2013, 12:57 PM   #3
CC69Rat
CC69Rat's Avatar
TDE is the code for a 3:07 truck rear end. The only way I know to tell for sure is the dia of the pinion shaft.
What does your mechanic think it might be?
Measure it from the back side of one backing plate to the other and post the length.
I think it's a truck rear end. Sounds like it to me. Leafs or Coils?
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 03-07-2013, 08:27 AM   #4
BionicABs1
Its is coil springs and I do believe you're right. I think its a truck rear end also.
Old 03-07-2013, 08:42 AM   #5
lolife99
67-72 parts collector,…
lolife99's Avatar
Dana 60?
Did you see this thread?
http://67-72chevytrucks.com/vboard/s...d.php?t=550670
Keith
Convert to disc brakes.
Old 03-07-2013, 08:55 AM   #6
CC69Rat
CC69Rat's Avatar
Dang man .. learn something new every day. I never knew (have never seen) a Dana in a 1/2 ton. Cool stuff.
Chad
