Old 03-06-2013, 12:43 PM   #1
register
register's Avatar
ARA Air Conditioning???
What should I do?
It is not working but the clutch cycles on..
and it blows but not cold. I think there is a bad leak somewhere.
should I not waste my time and buy a newer unit?
It is in rough shape..
What is the best unit to buy for 1970 and easiest to install?
register is offline   Reply With Quote
Old 03-06-2013, 12:49 PM   #2
71K20chevy
71K20chevy's Avatar
Re: ARA Air Conditioning???
I've heard good things about Vintage Air...but they're over $1300
71 K20
64 GMC mud truck
71K20chevy is offline   Reply With Quote
Old 03-06-2013, 01:05 PM   #3
Lee H
Lee H's Avatar
How about going to an A/C shop and getting an estimate to repair and recharge.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 03-06-2013, 01:40 PM   #4
MARKDTN
Ditto that. Don't give up without seeing what is wrong.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 03-06-2013, 02:16 PM   #5
chopnchaneled
chopnchaneled's Avatar
X's 2 on what Mark said, if i recall correctly ara used a york piston type compressor and they were bad to vibrate and the seals went out. alan grove makes an aftermarket mount for the later compressors, 508 sanyo etc. if thats the case.
I don't think we get smarter as we get older. We just run out of Stupid things to do.
chopnchaneled is offline   Reply With Quote
Old 03-06-2013, 02:20 PM   #6
hyatt
I had a auto repair business for 25 years specializing in ac repair
worst case on the inside unit is a bad expansion valve If compressor is bad update to sanyo type compressor but you should be able to fix much cheaper than replace
1946 car hauler
1948 surburban
1937 chevy sedan
1940 olds sedan (project)
1967 ss396 chevelle
1999 dually crewcab(24000 miles)
hyatt is offline   Reply With Quote
Old 03-06-2013, 02:36 PM   #7
register
register's Avatar
very difficult to find a honest repair shop in Toronto
#1 that you can trust!
#2 that has worked with older R12 units
#3 has the knowledge to pull it off
Old 03-06-2013, 02:41 PM   #8
chopnchaneled
It just dawned on me where your located, it probably only got used two days a year
Old 03-06-2013, 02:50 PM   #9
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
I'll take it from ya and I'll fix for my truck
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 03-06-2013, 07:54 PM   #10
Daaaanz67
Not tying to hack but I also have a unit like this and was wondering if ARA would be 134 comparable? Going to marry this with my ls style compressor
Daaaanz67 is offline   Reply With Quote
Old 03-06-2013, 08:00 PM   #11
TobyArnot
Quit if it's not FUN!!!
TobyArnot's Avatar
Seriously, the old R12 systems do have a tendency for the compressor seals drying out and leaking. That's why on newer systems, the compressor cycles on with the unit in defroster mode. Could be, that with limited running time, that's what you're dealing with. I second the "have it checked by a pro" before trashing the system. You might get it working for "lo-bucks".
TobyArnot is offline   Reply With Quote
Old 03-06-2013, 10:29 PM   #12
buckskins4ever
buckskins4ever's Avatar
It has been said, but I will add and agree. I think you should have a dye run done to verify your seals are bad on the compressor. If the blower unit is working, the worst case senario is new compressor, drier, and conversion over to r134. you wont find r12 and if you did it would be outrageous priced to recharge.
since its already there I wouldnt dream, of ripping it out and starting over with Vintage air.
buckskins4ever is offline   Reply With Quote
Old 03-07-2013, 06:51 AM   #13
Andy4639
Old member
Andy4639's Avatar
Wink Re: ARA Air Conditioning???
You could take the compressor off and put a late model Chevy pancake are a aftermarket compressor on it and while your at it have it swapped out to 134 A with new condensor, evaperator, acumaltor and a office tube inline. I did mine and love it.
I bought most of it from Vintage air. The evaperator and acumelator are parts house parts.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 03-07-2013, 08:40 PM   #14
tinsoldier
tinsoldier's Avatar
How often does it cycle? If it cycles on and off often, that means it is low on freon. I would suggest you to service the system yourself. You can buy all these tools at harbor freight and keep it for future usages..
1. Vacuum pump---> http://www.harborfreight.com/two-sta...ump-66466.html
2. AC guages--->http://www.harborfreight.com/a-c-man...set-92649.html
I converted mine to envirosafe freon which is basically similar to redtek. These freons are larger molecules and suppose to not leak like r134a. You can get these here pretty cheap.
http://autorefrigerants.com/co00033.htm
Don't let air conditioner system scares you. Its not hard. On youtube they can show you how to service it. However if you system is old, I would suggest you to change to a new drier and expansion valve, and new o-rings. Do this before you evacuate the system via the vacuum above.
tinsoldier is offline   Reply With Quote
Old 03-11-2013, 06:47 AM   #15
hannahjo
It is better that you get it checked at a good air conditioning repair servce centre.
hannahjo is offline   Reply With Quote
Old 03-11-2013, 07:04 AM   #16
register
register's Avatar
THat link is for home A/C repair?
Old 03-11-2013, 07:55 AM   #17
Andy4639
Old member
Andy4639's Avatar
Sorry if I missed it but what freon are u running? If it's R-12 then u should carry it to a AC service shop and let them check it out.
I converted mine over to 134-A several years ago I just toped mine off yesterday with Artic Freeze.
Old 03-11-2013, 08:00 AM   #18
register
register's Avatar
R12
Old 03-11-2013, 08:16 AM   #19
Andy4639
Old member
Andy4639's Avatar
If you have the guages and the R-12 add a couple of cans to it and see what happens. if it starts cooling then take it and have it serviced.
