Old 03-06-2013, 01:49 PM   #1
BIG DADDYS 84
6 lug rear in 1/2 ton?
ok i know its not cool,but what a deal.picking small parts at local pull a part,found k series 1/2 ton with new rear end. 373 and posi,for $65.00 complete.who could resist? wanting to put in my 84 stepside.other than wheels different is there any thing elese i need to know? thanks guys
BIG DADDYS 84 is offline   Reply With Quote
Old 03-06-2013, 02:01 PM   #2
J Knight
J Knight's Avatar
Re: 6 lug rear in 1/2 ton?
I dont know for sure but K10's have a slight lift compared to a C10. You may want to check the pinion angle when you get it installed.
John
82 Chevy Silverado 350ci/TH350
J Knight is offline   Reply With Quote
Old 03-06-2013, 03:33 PM   #3
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I've done the swap the other way. I had a 4wd truck with a bad rear so I put a 2wd rear into it. In my case, I swapped the axle shafts to retain the 6 lug pattern in the truck, but the axles swapped right in and the entire rear end itself bolted in.
Old 03-06-2013, 08:31 PM   #4
Rubble
I did the same swap as this,but the donor truck was a 79 heavy half.If I remember correctly the axles on the heavy half were a bit thicker than the 4x4 axles so I had to run 5 bolt wheels on the back til I got hold of another set of axles.I dont think they would fit into the spiders,either that or the outer bearings....
1977 Chev C30 454/465/14ff DRW
1974 Chev C20.350/465/14ff
" Rock n Roll ain't noise pollution"
Rubble is offline   Reply With Quote
Old 03-11-2013, 09:38 AM   #5
BIG DADDYS 84
ok, i have an 1984c10 2wd shortbed stepside.it has the original 3.07 10 bolt single traction rear end. i bought an 1984 k10 rear diff that is 373 posi. my reserch shows axle length to be different. k10-6lug c10-5lug.this dos~nt bother me right now. i can run 6lug ralleys on rear and 5lug ralleys on front. my concerns are installing 4x4x rear into my2wd frame and springs and pin angles ect. thanks guys for any info.
Old 03-11-2013, 03:18 PM   #6
Rubble
They should be the same,I swapped a rear axle from a 79 2wd to a 80 4wd. Spring perches were the same. Also swapped a rear axle from a 87 K15 to a 83 C10. Same thing,perches lined up,can't remember if I changed out the yoke or not....
Old 03-13-2013, 10:51 AM   #7
BIG DADDYS 84
thanks,rubble
Old 03-13-2013, 07:53 PM   #8
Rubble
No problem,hope it helped eh....
Old 03-14-2013, 08:17 AM   #9
ElGracho
Gentleman Jim Driver
ElGracho's Avatar
Shock mount brackets are a little different too.
Joe
'75 GMC Gentleman Jim
'84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter)
'85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans
also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '89 R3500 Flatbed
ElGracho is offline   Reply With Quote
