Old 03-06-2013, 08:17 PM   #1
Squareforceone
Squareforceone's Avatar
Hard starting.
My truck has always been a bit hard to start it gets really bad during the winter. i have messed with the choke some many times and i'm fairly confident that it's adjusted right but it still seems to be hard to start at first usually have to pump it and then give it some gas on the first start up of the day. I'm just curious what other things could cause this besides the choke.. fuel pump maybe?
Rust is better than rice.
Squareforceone is offline   Reply With Quote
Old 03-07-2013, 08:16 PM   #2
Squareforceone
Re: Hard starting.
ttt
Old 03-07-2013, 08:24 PM   #3
pwradder
pwradder's Avatar
Re: Hard starting.
is it a holley or rochester? is it starting okay then idling too low or does it take forever to fire?
1977 srw cc lb 396/700r/4:11's/6'' bds lift/ 35's. sold
1986 suburban 350/700r/3:73's 31's: parted out.
1980 silverado swb 5.3/700r/ 2'' drop/ daily driver. sold
1985 c10 long bed 5.3/700r/2'' drop/17" wheels/ daily driver. sold
1970 c10 long bed-new project! getting ready for the 6.0
pwradder is offline   Reply With Quote
Old 03-07-2013, 09:58 PM   #4
JellyBeanDriver
Re: Hard starting.
subscribing - I have similar problems with a QJ carb'd 86' C30 crewcab dually, 454.
JellyBeanDriver is offline   Reply With Quote
Old 03-07-2013, 10:32 PM   #5
motornut
78K & 79C Jimmys
motornut's Avatar
Re: Hard starting.
hows the fuels lines and rubber bits,sending unit
remove the line from the pump to the carb ,clean it out
hows the fuel filters
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 03-07-2013, 10:36 PM   #6
wilkin250r
wilkin250r's Avatar
Re: Hard starting.
Without being there in person, it's not easy to determine what is "hard starting" or just normal starting for cold weather, so let's try a little background info to start.
In order for fuel to burn, it must vaporize. That's much more difficult in cold weather than warm weather, for obvious reasons. It's also much more difficult for CARBURETED vehicles because of the way carburetors work. You're just using moving air to pull fuel from the carb bowl, it's not a really powerful force. As a result, the fuel passages in a carburetor are fairly large, compared to fuel injection, and result in LARGE droplets of fuel that don't want to vaporize easily, and certainly don't want to vaporize when they hit cold intake passages.
So the solution is to dump LOTS of fuel into the intake, either by using the choke or by pumping the gas several times to get the accelerator pump to inject a bunch of fuel into the intake. With such an over-abundance of fuel, you'll get some of it to vaporize and allow your car to start.
So my first question is: Are you pumping the gas before you try to start? How many times?
I know a little about cars, but if you have a question about electricity or sport quads, I'm your man!!!
wilkin250r is offline   Reply With Quote
Old 03-08-2013, 11:47 AM   #7
Squareforceone
Re: Hard starting.
quadrajet fairly new fuel filter have to pump several times like the choke isn't working but it is... and i know how a carb works and that they are harder to start than fuel injection and yes i'm pumping it before hand a lot....
Old 03-08-2013, 01:19 PM   #8
hotstuff
Re: Hard starting.
Check the choke linage for freeness ,while you have the air cleaner off ,check the accelerator pump shot and choke flap gap
hotstuff is offline   Reply With Quote
Old 03-08-2013, 06:36 PM   #9
wilkin250r
wilkin250r's Avatar
Re: Hard starting.
Agreed, the next thing I would investigate would be the accelerator pump.
Old 03-08-2013, 06:42 PM   #10
pwradder
pwradder's Avatar
Re: Hard starting.
x3 on the accel. pump, you can check it by holding the choke flap open and looking down the primary side with a light-you should see a strong shot of fuel when you pump the gas (engine off of course).
Old 03-08-2013, 09:47 PM   #11
86c20
86c20's Avatar
Re: Hard starting.
One thing to think about is the lift pump on the motor if its not holding fuel in the line they are gard starting. Try cranking it for 5 sec then give it a pump on too to set the chock and add fuel then start it. Doing that will tell u if it is lack of fuel in the carb
1986 c20 "the hillbilly" 350 sm465 3.42gears 21mpg at 70mph
1985 k30 "the ice cream truck from hell" no rust az truck
197-8??? c30 "ramp truck" 454
1978 monte carlo 350 350th with 2.73 gears. no rust. sc car
86c20 is offline   Reply With Quote
Old 03-09-2013, 12:31 AM   #12
JellyBeanDriver
Re: Hard starting.
Is this common? (the mechanical fuel pump leaking back?)
