Old 03-06-2013, 10:28 PM   #1
jrobertop88
jrobertop88's Avatar
rear end swap
I have a 65 c10 stepside, my rear end is grinding and noisy, what year truck can I take a posi rear end from and be a direct fit or close to it? If there's any pics cool....
Thanks fellas.
jrobertop88 is offline   Reply With Quote
Old 03-07-2013, 02:21 AM   #2
Captainfab
60-66 Nut
Re: rear end swap
Assuming your truck has the coil springs and trailing arms, a direct bolt in differential would be from a '65 to early '70. If you are just looking for a posi unit to install in your housing, the truck 12 bolts were used in most C10's from '63-'82, and K10 and K5 Blazers from '63 to '79.
Old 03-07-2013, 03:02 AM   #3
jrobertop88
Re: rear end swap
Thanks for the info...
Old 03-07-2013, 12:54 PM   #4
bigdlb12
bigdlb12's Avatar
Re: rear end swap
depends on your bolt pattern
I converted mine to chevy small bolt front clip and a rearend off of a 1969 firebird
bigdlb12 is offline   Reply With Quote
Old 03-07-2013, 01:04 PM   #5
T2vigil
T2vigil's Avatar
Re: rear end swap
Thread Hyjack in progress. What years will fit a 64 C10 that have 6 lugs? Looking for 373 or taller gears so I can get rid of the 410/411 that I have now.
T2vigil is offline   Reply With Quote
Old 03-07-2013, 01:43 PM   #6
1963c-10
1963c-10's Avatar
Re: rear end swap
same as what captainfab said above
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
