Old 03-06-2013, 11:48 PM   #1
Hart_Rod
Hart_Rod's Avatar
Like new SWB one piece driveshaft
****SOLD!!****
I'm having a custom built aluminum driveshaft made to install my LS3/6L80E in my 68 SWB, so I'm listing this steel one for sale. I had this driveshaft custom built with all new parts including the yoke, u-joints and tube. It measures 54.5" from center cap to center cap and has has less than 5K miles on it. Asking $175.
R/
Hart_Rod is offline   Reply With Quote
Old 03-07-2013, 12:25 AM   #2
HotRod C/10
HotRod C/10's Avatar
Re: Like new SWB one piece driveshaft
rob what trans were you running? short or long tail?
SOLD -77 CHEYENNE SWB,
LS SWAPPED
-1976 SILVERADO
YUBA GOLD/NEUTRAL (2-TONE)
HotRod C/10 is offline   Reply With Quote
Old 03-07-2013, 07:38 AM   #3
Hart_Rod
Hart_Rod's Avatar
Turbo 350, short
Old 03-07-2013, 08:37 AM   #4
lolife99
67-72 parts collector,…
lolife99's Avatar
Is your old sbc engine stands in the V8 position,... or the 6-cylinder position?
Keith
Convert to disc brakes.
Old 03-07-2013, 08:58 AM   #5
HotRod C/10
......according to TCI's website these two trannies are different lengths.
LS SWAPPED
-1976 SILVERADO
Old 03-07-2013, 10:04 AM   #6
Hart_Rod
Hart_Rod's Avatar
Is your old sbc engine stands in the V8 position,... or the 6-cylinger position?
V6 position
Old 03-07-2013, 04:46 PM   #7
Hart_Rod
Hart_Rod's Avatar
Here's a picture of the tailshaft.
Old 03-07-2013, 10:59 PM   #8
HotRod C/10
Ok I am stabbing my trans tommorrow and will get dims.
LS SWAPPED
-1976 SILVERADO
Old 03-07-2013, 11:17 PM   #9
Hart_Rod
Hart_Rod's Avatar
Sweet! Let me know.
Old 03-09-2013, 09:15 AM   #10
Hart_Rod
Hart_Rod's Avatar
What did you figure out?
Old 03-12-2013, 08:47 AM   #11
Hart_Rod
Hart_Rod's Avatar
bump
Old 03-15-2013, 09:12 AM   #12
Hart_Rod
Hart_Rod's Avatar
ttt
Old 03-23-2013, 11:36 AM   #13
Hart_Rod
Hart_Rod's Avatar
bump
Old 03-24-2013, 05:58 PM   #14
frmula505
frmula505's Avatar
I need one, HotRod C/10 told me about this thread. I had measured mine end to end (i know not as accurate). Anyways mine was 55 1/4 end to end. I need another inch. So it would need to be 56 1/4 end to end. That looks close to what you have. How much shipped to new mexico 87506.
1961 GMC Suburban Custom
1969 Short wide project http://67-72chevytrucks.com/vboard/s...d.php?t=535479 (SOLD)
1959 Apache fleetside (frame off in progress) http://67-72chevytrucks.com/vboard/s...d.php?t=348746
1960 Apache short/narrow shop truck http://67-72chevytrucks.com/vboard/s...d.php?t=350780 (SOLD)
1951 Plymouth leadsled project
2005 Corvette conv. Procharged
1969 Corvette stingray
2006 Cadillac XLR-V
1950 Oldsmobile 98 custom project
frmula505 is offline   Reply With Quote
Old 03-24-2013, 06:46 PM   #15
Hart_Rod
Hart_Rod's Avatar
How about $200 shipped?
Old 03-25-2013, 09:45 AM   #16
frmula505
frmula505's Avatar
Sounds good, you want to do paypal? What is the measurement end to end?
2006 Cadillac XLR-V
Old 03-25-2013, 10:41 AM   #17
Hart_Rod
Hart_Rod's Avatar
Paypal will be good, . I'll measure it for you this afternoon when I get home.
Old 03-25-2013, 10:52 AM   #18
frmula505
frmula505's Avatar
2006 Cadillac XLR-V
Old 03-25-2013, 11:09 AM   #19
HotRod C/10
Hope this works out guys.
LS SWAPPED
-1976 SILVERADO
Old 03-25-2013, 05:59 PM   #20
Hart_Rod
Hart_Rod's Avatar
Here's a picture with the overall measurement (EDIT from the center of the rear u-joint).
Thanks for the assist!!
Old 03-25-2013, 08:17 PM   #21
HotRod C/10
Its the same length as the one he just gave me..........Bummer
LS SWAPPED
-1976 SILVERADO
Old 03-25-2013, 08:31 PM   #22
Hart_Rod
Hart_Rod's Avatar
Now I'm confused.
Old 03-25-2013, 08:54 PM   #23
HotRod C/10
Lol.....I bet.....frmula505 gave me his old drive shaft yesterday same length as yours.........no jokes please
LS SWAPPED
-1976 SILVERADO
Old 03-25-2013, 10:22 PM   #24
Hart_Rod
Hart_Rod's Avatar
Ok, I see what you're saying now. The measurement in the above picture was from the center of the rear u-joint. Here's a picture with the measurement from end to end.
Old 03-28-2013, 03:07 PM   #25
frmula505
frmula505's Avatar
That should work for me, it will give me close to an inch more center to center of u-joint. Paypal sent. I ran my old driveshaft for a long time, just wasn't going in far enough. This caused a vibration at higher speeds, that got worse as the rear u-joint got bad.
2006 Cadillac XLR-V
