Old 03-07-2013, 03:51 PM   #1
Blue_Aura
Blue_Aura's Avatar
Where can I get an electrical diagram for my 62?
So I found out that my front blinker lights up when I step on the brake! The gas gauge doesn't work, and my ignition has an intermittent issue. I am suspecting that the PO really hacked up the wiring.
I am about to install my HEI distributor, so I will be needing to hookup a wire to the IGN, non-fused spot on the fuse block. While I'm at it, I should check to see what anyone has done with all the wiring.
Current Vehicles:
'62 C10 - 350 (current project), '03 Tahoe (C Series)
Some Past Projects:
'69 Nova - 350 , '70 1/2 Camaro Z28 - LT1 350, '73 K20 Full-time 4x4 - 400 SB, '77 1/2 Camaro Z28 - 350, '84 Camaro Z28 - 305, '68 Buick - 430 BB
Blue_Aura is offline   Reply With Quote
Old 03-07-2013, 03:58 PM   #2
jayoldschool
Moderator
Re: Where can I get an electrical diagram for my 62?
The factory service manual has all the electrical diagrams in the back for every option/engine. You should grab one off ebay.
jayoldschool is offline   Reply With Quote
Old 03-07-2013, 04:36 PM   #3
WhippinSaw
WhippinSaw's Avatar
I have used the service manual but you can find some nice color coded ones in the stickys. http://67-72chevytrucks.com/vboard/s...d.php?t=378484
WhippinSaw is offline   Reply With Quote
Old 03-07-2013, 04:54 PM   #4
Blue_Aura
Blue_Aura's Avatar
Awesome... THANKS!!!
Current Vehicles:
Some Past Projects:
Old 03-07-2013, 04:55 PM   #5
Blue_Aura
Blue_Aura's Avatar
Since I am tearing into the truck, that might not be a bad idea! Thanks.
Current Vehicles:
Some Past Projects:
Old 03-07-2013, 05:01 PM   #6
Blue_Aura
Blue_Aura's Avatar
Thanks to you mentioning the Stickies, I found a thread concerning the flasher issue. Cool! Thanks again.
Current Vehicles:
Some Past Projects:
