Old 03-07-2013, 08:07 PM   #1
rs74
rs74's Avatar
Switching from hydraulic brakes to vaccuum.
I am going to look at a cab sunday and it has the hydraulic brake system on it. If I want to take that off and put the Vac brake booster and master cylinder on it what all do I have to do. Is it just a matter of unbolting one and bolting up the other. Are the rods different?
Roy
85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818
1987 R10 shortie
rs74 is offline   Reply With Quote
Old 03-07-2013, 08:55 PM   #2
v30crewcab
v30crewcab's Avatar
Re: Switching from hydraulic brakes to vaccuum.
I have run into the pin on the pedal being a different size, but not sure if they were all that way. otherwise it will bolt right in.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
Old 03-07-2013, 09:36 PM   #3
rs74
rs74's Avatar
I am going to get the vin # so I can see what this cab was originally off of.
Roy
1987 R10 shortie
Old 03-07-2013, 10:11 PM   #4
INSIDIOUS '86
INSIDIOUS '86's Avatar
Why do you want to change?
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 03-07-2013, 10:12 PM   #5
rs74
rs74's Avatar
Just ran the VIN and it is a canadian truck that came out with a diesel. Looks like I would have to change the wiring harness as well. Not sure about anything else.
Roy
1987 R10 shortie
Old 03-07-2013, 10:15 PM   #6
rs74
rs74's Avatar
I just figured that I would put the new cab back the same way the old one was set up. The new cab is from a diesel truck and has different brake system.
Roy
1987 R10 shortie
Old 03-07-2013, 11:54 PM   #7
hatzie
Moderator
hatzie's Avatar
I'd keep the hydroboost.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 03-07-2013, 11:57 PM   #8
rs74
rs74's Avatar
Is that supposed to be better than what came out on the gas engined c10's? I usually only see them on the diesel and one tons.
Roy
1987 R10 shortie
Old 03-08-2013, 12:04 AM   #9
meatwagon83
meatwagon83's Avatar
you only see them on diesels and one tons for a reason, they are a better braking system and dont rely on engine vacuum, designed for stopping the weight of a trailer in addition to the truck, i would surely keep the hydroboost!
meatwagon83 is offline   Reply With Quote
Old 03-08-2013, 12:07 AM   #10
rs74
rs74's Avatar
I will have to do some reading up on hydroboost brakes then. I know absolutely squat about them. So bare with me if I seem to have some stupid question. Is it that hard to convert over to hydro if you are on vaccuum. If someone was wanting to do the swap then it is just a matter of putting the hydro on. What about prop valves and the like.
Roy
1987 R10 shortie
Old 03-08-2013, 12:31 AM   #11
meatwagon83
aside from getting the lines that go to the power steering pump, it should be a bolt in, just make sure you have good brake lines, that system puts out some pressure! my 6000 pound dually will stop on a dime!
Old 03-08-2013, 12:46 AM   #12
83GMCK2500
Not to mention the correct power steering pump reservoir. That 3rd line, the low pressure/vent return from the hydroboost back to the reservoir needs a home.
Devin
1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt
1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050
1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350
My Introduction with my '83s History
New Daily, the '96
83GMCK2500 is offline   Reply With Quote
Old 03-08-2013, 12:55 AM   #13
bilfman
bilfman's Avatar
I would stay with the hydro boost, built for better braking. Essentially it delivers much better braking when towing, often when towing you can get into low vaccum situations often = poor braking, the hydroboost delivers consistent braking no matter what engine load/vacuum levels.
1979 Chevy Dually Crew 4X4 454, D60 Tru-trac, D70 Detroit Locker, 3.73, 4L80E/NP205
1971 GMC 3/4 Ton 4X4
bilfman is offline   Reply With Quote
Old 03-09-2013, 08:54 AM   #14
hatzie
Moderator
hatzie's Avatar
You can run a big cam without worrying about vacuum for your brakes.
And... The Hydroboost unit is much smaller than a Vacuum booster so it isn't in the way.
