Braided transmission oil cooler lines. Good source?
Looking to change out the tranny oil cooler lines during my transmission and motor swap. Any good suggestions or sources? I will be installing a transmission cooler and running it in series with the radiator trans cooler.
Posted via Mobile Device |
In the Forgotten far North.
![]() Join Date: Jul 2007
Re: Braided transmission oil cooler lines. Good source?
yOUR LOCAL HYDRAULIC HOSE & PARTS STORE ( THINK PARKER STORE OR EVEN JACKOVICH) CAN MAKE THEM UP FOR YOU.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015 1990 chevy suburban V2500 5.7L My cluster Mods-Nov 2007 overhead console Stereo install Round 2 Aug 2009 Heated/turn signal mirror upgrade |
Home Built '87
If you are able & want to take on a project, you can build them yourself.
Many videos on youtube how to do it, but best ones are from Koul Tool which is a little vinyl tool that helps sets the line into AN fittings. I made lines for my truck for the forst time last winter and none leaked surprisingly enough! So if I can do it I'm sure anyone can!! :-) https://www.youtube.com/watch?v=IL4kPrSZSEc
Gordon 1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424 1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833 Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969 |
summitracing has all the parts. not hard to do.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205 86 k30, 89 diesel burb, 76 gmc pathfinder 71 longbed 5.3 4l80 http://67-72chevytrucks.com/vboard/s...d.php?t=522535 |
Thanks for the input guys. I will check out the video. I have never really dealt with fittings or building lines. May be fun to learn how. LOL. All the fitting sizes and types always seemed overwhelming.
So what size or type of AN fittings would be needed? Line runs from the transmission into the radiator, out of the radiator, into the aux cooler, and out of the aux cooler back to the transmission.
Home Built '87
I think they were 6's and 8's if memory serves....check out my build about Nov '11
6an would be the same as the original lines. I would go here and do some searching as for what fitting you might need. http://www.holley.com/Index.asp?division=Earls
![]() 1985 C10 2004 Avalanche |
Hi I was looking over this ??? Myself I have a 1986 c10 2wd 700r4 350 5.7 tbi. I tjink its best that I use the brsided lines save bending braking and craking worries from the traditional lines. Now that I have answerd that ??? Should have install a transmission cooler also. I hear you guys talking about them but I never had one. Is my setup ok without it, or am I at risk of burning up my 700r4
Ok so I did a little online search and found a company (jegs) that offers a braided line for the 700r4. They offer a ket that runs braided lines to a 18 or 20 inch jegs trans cooler and back to the trans. Braided lines and 20 cooler all for right under $250. I would like to get some information form you guys before I buy and install this set up
AN lines are always hard to figure out so remember this little trick and no more worries.
Each number is about 1/16 inch. -4 AN would be 4/16 or 1/4 inch hose -6 AN would be 6/16 or 3/8 hose -8 AN would be 8/16 or 1/2 inch hose -16 AN would be 16/16 or 1 inch hose. -24 AN would be 24/16 or 1.5 inch hose. There are places online were you pick the right connector then the left connector then the type of hose you want and its length.They show you a picture of what the completed hose will look like then build it/them for you. |
yeller
Here is a great link, from our old pal Swervn
http://73-87.com/7387garage/drivetrain/tranny_hoses.htm Posted via Mobile Device
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
#13 |
Thanks for the good info looks very neat. I'm a army vet so I love neat also. The question I still have is, without my 700r4 being modified with shift kit and other things, should I be worry about buying a cooler or will I be just fine running the lines right to the factory raidator ?
#14 |
I would suggest going ahead and adding the second cooler if your budget allows. A nice setup with braided lines can be had for much less then the $250 you found if you just piece together it yourself. I think my setup cost around $180 and that was getting the largest cooler I could fine. It can only help control temps and especially if you pull or haul stuff it will make a big difference in the trans living a long life.
#15 |
Will do thanks again
#16 |
I know this is old but.... $115.
Transmission cooling lines to radiator, using hydraulic Lines. |
#17 |
What length and diameter hose did you use?
#18 |
#19 |
I did hydo lines from the local shop several years ago and love them.
I however did not run them to the front, I ran them under the bed and mounted a self contained B&M cooler, fan and thermostat. Cool transmission fluid leads to longer life of the transmission. I believe (and I could be rusty) that builders recommend that transmission fluid stay at 120* for long life. Well if you are putting fluid in a 195* radiator, guess what? |
