Old 03-07-2013, 09:59 PM   #1
Trsmotrhed
Trsmotrhed's Avatar
Fleetside tail light replacement help
I'm replacing the tail light panel on my 63 fleetside and asking what guys have done to tack weld the panel back. I can drill some holes in the lower portion of the bedside to tack weld but no way to get in the top portion. I'm sure I'll figure it out eventually but that's usually after I've tore something up. Thanks for any help.
Sold the 63 and have a 68 now.
63 SWB C10
LT1/4L60E, PS, PB, Disk Brakes, CPP 4" drop coil rear, 2.5" drop spindle w/ 1" drop coil. slotted rotors, front and rear sway bars. 18"x8" Cragar SS w/ 245/45R18
http://67-72chevytrucks.com/vboard/s...d.php?t=544174
Trsmotrhed is offline   Reply With Quote
Old 03-08-2013, 10:03 AM   #2
64fleetside
Re: Fleetside tail light replacement help
Panel bond
64fleetside is offline   Reply With Quote
Old 03-08-2013, 11:02 AM   #3
Trsmotrhed
Trsmotrhed's Avatar
Originally Posted by 64fleetside View Post
Panel bond
That's what I was thinking. Cut the old one off without damaging the bed, clean up real good and get a good panel bond. I'll need to make sure to keep the seam between bed side and tail light panel clean so it looks good. Think I'll head to the local body supply shop and see what they have. I've heard good things about panel adhesives. Just seems weird not welding it. Thanks for your help. I figured more guys had done this.
63 SWB C10
Old 03-08-2013, 12:33 PM   #4
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
I have a pair also just havent done it yet, so Ill be watchin you
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 03-08-2013, 12:53 PM   #5
Trsmotrhed
Trsmotrhed's Avatar
Talking Re: Fleetside tail light replacement help
Great, I feel the pressure on me now.
63 SWB C10
Old 03-08-2013, 01:17 PM   #6
aerotruk63
aerotruk63's Avatar
I'll be watching as well, that's double the pressure now!
Old 03-08-2013, 03:34 PM   #7
64fleetside
my buddy is a bodyman 30+ yrs, and I've seen that the metal will tear before the panel bond lets go on pickup rear bedsides. It is pretty amazing stuff.
Old 03-08-2013, 03:44 PM   #8
Trsmotrhed
Trsmotrhed's Avatar
I've seen those videos also, I'll give it a try. Lots of info on you tube on panel adhesive.
63 SWB C10
Old 03-09-2013, 01:30 AM   #9
Trsmotrhed
Trsmotrhed's Avatar
I could also weld the joint on the outside and smooth it like I've seen on some other trucks on here. Just getting ideas.
Like this
63 SWB C10
Old 04-28-2013, 12:40 PM   #10
Trsmotrhed
Trsmotrhed's Avatar
This is what I ended up doing. I removed the lower section that I could spot Weld to the side panel.
Before picture.
After I cut the lower section out.
After all welded back together.
Expoxy primered and ready for body filler and primer.
63 SWB C10
