Old 03-07-2013, 10:21 PM   #1
Ricks1971
Ricks1971's Avatar
swapping disc brake fronts from 5x5 to 5x4.75?
I woul like to change my 72 with disc front brakes from 5x5 to 5x4.75. I saw a post awhile back and can't find it. Going to be putting drop spindles on the front. any idea's guys?
Ricks1971 is offline   Reply With Quote
Old 03-08-2013, 01:31 AM   #2
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: swapping disc brake fronts from 5x5 to 5x4.75?
I vaguely remember a van rotor...
" That didnt make it any newer "
" Dont antique the equipment "
KQQL IT is offline   Reply With Quote
Old 03-08-2013, 02:25 AM   #3
maxxxy
maxxxy's Avatar
On my 1981 1/2 ton 2wd c10 I am using 1991 Camaro 1LE rotors. They are the exact same in all Specs except for the bolt pattern, which is 5x4.75".
Max
Max's bagged 81
81 rcsb bagged, 22s, build in progress
09 ext cab, 24" U2's, DD sub/amp
maxxxy is offline   Reply With Quote
Old 03-08-2013, 11:17 AM   #4
Ricks1971
Ricks1971's Avatar
this is the thread
http://67-72chevytrucks.com/vboard/s...d.php?t=319487
