![]() Join Date: May 2003
OEM style steering wheel
Does anyone make an OEM style steering wheel that's a little smaller in diameter ? I would like to keep the stock look, but don't like how big the original wheels are !
Gary
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 |
the boat guy
Re: OEM style steering wheel
Skymangs (board member) made a cut down wheel for his AD, cut the rim off of the factory wheel and used a smaller diameter hard plastic rim off of an early 80s ford steering wheel. Takes some welding, epoxy, some paint and bodywork but looks better thn some generic parts house or modern steering wheel.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
That's an idea ! Has anyone ever resized and OEM wheel ?
2WD Jimmy
![]() Join Date: Mar 2005
Yep. Actually there are a few on here that have done that, you might do a search, I think you'll find the threads.
Posted via Mobile Device |
Prestige Worldwide
![]() Join Date: Feb 2001
This was a pretty good article I found about this...
http://www.customclassictrucks.com/t...teering_wheel/ |
That was a good article, and exactly what I was thinking about. But I have a 72 and the 72 wheels are a bit different. 2 spokes and a texture for better grip, and some other detail.
Has anyone tried this on a 72 wheel ? Thanks for that link !!!
I recently cut down my stock '69 wheel. It was 17" now it's 15.5 which is perfect diameter for me.
![]() This shows the original 17" comparted to the 15.5" after being cut down. ![]() This is what it looks like in the truck. I slicked out the texted portion of the wheel and radiused the cut lines to carry the radius of the corners. This gives it an oem look with just a hint of a modern accent. Cheers! Mickm |
