Old 03-08-2013, 11:22 AM   #1
ArrowoodRodKustom
ArrowoodRodKustom's Avatar
1947-1954 Truck Cap On 1985 Chevy Car Hauler Chassis
Been thinking about purchasing a car hauler to pick up the projects around the shop. Found a good deal on a 1985 Chevy on craigslist has a 350 in it with an auto trans, I was thinking about buying this & putting a cab of a '47-'54 Chevy on it, give it that classic look to haul cars around
wondering if anyone has done this before? if so what all is involved, what needs to be modified, how hard is the swap..etc photos will help as well
thanks for the help!
ArrowoodRodKustom is offline   Reply With Quote
Old 03-08-2013, 11:49 AM   #2
NEWFISHER
NEWFISHER's Avatar
Re: 1947-1954 Truck Cap On 1985 Chevy Car Hauler Chassis
The front suspension is a little wider than the AD trucks, but the 1 1/2 ton AD cab/chassis cabs are plentifull and cheap. they also have a wider and longer front clip that would "fit" or look a little better than a 1/2 ton cab. Go for it!
NEWFISHER is offline   Reply With Quote
Old 03-08-2013, 12:18 PM   #3
solidaxel
solidaxel's Avatar
...... 10 - 4 ............
Take lots of pics, I think you will be happy with the outcome
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 03-09-2013, 05:43 PM   #4
jremig
Have you ever seen an episode of Counting Cars? That's one of those spin off shows from Pawn Stars. The guy from the show has one done like what your talking about. Its pretty cool.
Joe
jremig is offline   Reply With Quote
Old 03-11-2013, 09:27 PM   #5
ArrowoodRodKustom
Joe
nope haven't seen that show, but sounds cool, I'll see if I can find some pics online
I've been looking on Craigslist for a 1 ton truck in Michigan for cheap but no luck, have found a 1947 Ford 1 ton & a 1951 Ford 1 ton both very clean full trucks & good price so may go that route if I don't have any luck with the Chevys..not sure on width or anything on the Fords though
Old 03-11-2013, 09:43 PM   #6
NEWFISHER
NEWFISHER's Avatar
Look at motorhomes too. Low milage, big blocks and with rot damage, cheaper than a 1 ton truck. They will also have the frame rail length you are looking for.
Old 03-11-2013, 09:49 PM   #7
mr48chev
mr48chev's Avatar
Half, 3/4 or 1 ton fenders and hood would work but I think the 1-1/2 nose would be a better fit with the big wheel openings and longer nose. The cabs are the same though.
At lest you could buy that one, use it and then take your time deciding if you wanted to swap cabs and then have time to slick the cab and nose out and paint them before doing the swao.
My ongoing truck projects:
