03-08-2013, 02:37 PM | #1 |
Crewcab 4x4 help
What would have to be done to turn an 80's crewcab dually into a short bed 4x4? I know there's info out there on the long bed to short bed conversion, but not much in the way of the 4x4 conversion. Were there any crewcabs produced that were 4x4 from the factory that I could try to track down as a starting point? I had originally intended on finding a Suburban 2500 4x4, but those are pretty rare in the below $3k price bracket. At least up this way. I figure a crewcab dually is easier to find and I can sell what parts I don't need to purchase what I do need.
Here's the final goal: Seating for at least 3 adults Enclosed area for carrying groceries in bad weather 4wd to prevent getting stuck in bad weather Enough cargo space to carry around engines or fenders or such Ability to tow about 6,500 pounds |
03-08-2013, 02:45 PM | #2 | |
Re: Crewcab 4x4 help
1969 chevy camaro Z28 #matchin Factory 4wheel disc 1969 chevy cst10 big block overdrive 5/7 drop dog dishs 1997 gmc yukon 2 door 2 wheel drive project 4/5.5 22s 2004 gmc sierra dually 4/4 lowering daily driver |
03-09-2013, 12:17 AM | #3 |
Ask this over in the 4x4 section and you'll probably get more replies on the 4x4 swap part. There are a bunch of us over there that have done it. Good luck on your project. 4x4 Crews are cool!
1990 K5 Blazer (sold) 1983 SWB C-10 to K-20 Conversion |
03-09-2013, 12:25 AM | #4 |
I no where an 85 burban 3/4 with a 6.2 4x4 is for 1600... Needs a tranny tail shaft. Sucks ya are so far away :/
When in doubt, throttle it out! 1974 Chevrolet Custom K20 2005 Ford Ranger Edge 1985 Chevrolet Custom Deluxe C10 |
03-09-2013, 05:17 AM | #5 |
This will help you some http://67-72chevytrucks.com/vboard/s...d.php?t=546339 or look around on this http://67-72chevytrucks.com/vboard/f...play.php?f=141 for 4x4 swaps.
03-09-2013, 11:56 AM | #6 |
They made 4x4 crews in both dually and srw, not sure if there was a factory short box. But long boxes are out there.
Here is one that I saw for sale. http://www.rustfreeclassics.com/Chev...ack_Silver.htm Looking for one in the 80's is a lot easier, I wanted a round eye and it took me 2 years of searching to find a 79 or prior crew dually 4x4.
1979 Chevy Dually Crew 4X4 454, D60 Tru-trac, D70 Detroit Locker, 3.73, 4L80E/NP205 1971 GMC 3/4 Ton 4X4 Last edited by bilfman; 03-09-2013 at 11:56 AM. Reason: coz |
03-10-2013, 01:17 AM | #7 |
A short bed was only a 1/2 3/4 and 1 ton was long beds only.
03-10-2013, 01:39 PM | #8 |
Fixed that for ya. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
03-10-2013, 08:09 PM | #9 |
I have a 4X4 crew cab, they don`t seem to be very common around here. You can convert a 2wd, but it will take some time and money. Do you need the Dana 60 front axle or can you make due with a 10 bolt or Dana 44. If you don`t need a 60, or a Dually you can save some $$ by using a 3/4 ton for a donor.
03 GMC Yukon XL 2500 Quadrasteer, wife`s DD 84 Chevy K30 CC SRW 55 Chevy 210 2dr post |
03-11-2013, 02:07 PM | #10 |
I'm thinking it'll be best for me to spend the time and energy trying to find a 1-ton 4x4 crew cab single wheel to start from. It's not the easiest thing to find, but they are out there as I'm finding out.
My fallback plan is the dually 4x4 and hoping that there's someone out there willing to swap axles and beds with me so that we can both do conversions on the cheap. I did find an old towtruck crewcab dually, but I'd imagine taking the tow bed off would be a nightmare. |
03-11-2013, 10:33 PM | #11 |
1979 Chevy Dually Crew 4X4 454, D60 Tru-trac, D70 Detroit Locker, 3.73, 4L80E/NP205 1971 GMC 3/4 Ton 4X4 |
03-11-2013, 11:02 PM | #12 |
I have a 4x4 crew cab dually for sale. Project. It currently has no/trans in it. I have a 92 cummins I bought for it. I have almost everything to do the swap except trans.
http://67-72chevytrucks.com/vboard/c...ic-k-35&cat=13 Posted via Mobile Device
