Old 03-08-2013, 02:59 PM   #1
racerx8413
5 lug conversion axles with discs?
I've got a 65 rear end - with these,
http://www.classicperform.com/Store/...k/6569RACK.htm
Can I slap disc on these axles, with the brackets, or will this axle need to be modified?
racerx8413 is offline   Reply With Quote
Old 03-08-2013, 08:59 PM   #2
68Gold/white
Re: 5 lug conversion axles with discs?
I'm not sure what you are talking about, for the brackets...
By looking at the ad, it looks exactly like what you need, you'll need 5 hole drums (I not sure what all came in that "kit"...
How much are just the axles???. Moser had stock type "C" clip axles, for $260.00/pair, recently, I'm not sure if that price is still good, or if they will make them for your particular application...
I'm wondering about the interchangeability of parts in that ad. The 12 bolt rear end came out in 1965. The ad said the axles would fit 63-70's????
68Gold/white is online now   Reply With Quote
Old 03-08-2013, 09:50 PM   #3
hugger6933
If your asking what I think your asking, Yes a little modification is needed. The center hub concentric has to be turned down a sight bit as it is a little larger than the center hole of the disc brake ones are. now the bracket bolt on to the axle tube so that should not matter
hugger6933 is offline   Reply With Quote
