![]() Join Date: Aug 2001
engine weight...help!
i thought i remember reading here that the weight of a completely assembled small block engine is around 750 pounds. i pulled my 327 out tonight and it seems to be bouncing pretty good on my 1000 pound rated stand. am i ok?
I'm pretty sure that your absolutely fine. I really doubt that your small block could exceed the 1000 lb limit. I'm not sure on the weight of a small block, but I really doubt that it's be more than 1000 lb....
Brian Pal 1971 Cheyenne 10 454/th400-Undergoing a full frame off resto. 1972 Chevy short/step 2wd, 350/th350 1983 M1009 CUCV Military K5 Blazer 1981 Dodge 1 ton 4x4 dually flatbed |
![]() Join Date: Oct 2002
I have a full big block 454 on a 750lb stand right now. It scares me a lot. I have a piece of wood under the front of the motor to keep it from bouncing too much. Oh yeah I got the 454 to toss into the suburban.
1969 Chevy Project SWB Fleet, 20s, 5.3, t56, in the weeds. 1970 Chevy Truck cab on a 1979 Jimmy frame-8.1 liter 496 bbc/sm465/np203-jeds doubler-np205/d60/14bff Welded/42 tsls on recentered H1s 1998 Chevy Crew Cab K3500 SAS'd with hpd60, links and swayaway coilovers. 8.1l vortec DD/towrig "I like long walks, especially when they are taken by people who annoy me. " |
I was pretty skittish when I had my fully assembled 327 on my borrowed engine stand. I finally stuck a heavy stick of wood under the oil pan to help support the front of the engine. It sure gives you a little piece of mind.
Unrestored 68 C-10 CST. Original 327. 4-Speed CH465. 50k or so miles. TREASURER, Drum Brake Club. |
A fully assembled smallblock with all cast iron components is rarely over 600 pounds.
its all about the +6 inches
Yeah, less than 600 normally.
I can understand the concern witht eh engine stands flexing though. I have a parts store special engine stand and it is rated for 750lbs. However, when i put that caddy big block on there it looked like the charlie brown X-mas tree. (y'all remember that cartoon?) I used a bottle jack for peace of mind under the engine to help brace it. |
thanks guys.........
i had visions of that thing coming down on my leg, my wife not being able to hear my faint cries for help over the roar of my compressor, and having to cut off my leg to save my life. ![]() i am going to brace as you all have suggested, and begin the tear down ![]() |
Livin' it up.
![]() Join Date: Nov 2001
It shouldnt be that heavy but those stands do like to flex... i had a fully done BB on my 1k stand and it still flexed quite a bit... I wonder what that merlin weighs in at all done..
-Greg; Sold the 69 C20. It's off to a better home with more love! Now onto the 86 CUCV M1009; K5 blazer with 6.2L diesel, corp 10 bolt axles, Detroit locker in the rear, trutrac front, 3.73 gears, 35" tires. ![]() |
CCRider
I have one those that supposed to break down for easy storage. It flexed so much I welded it together and added a brace...it still moves quite a bit with a big block on it
72 GMC Sierra SWB almost finished---- 84 Softail Olive Branch MS |
