Old 03-09-2013, 05:12 PM   #1
'65 chevy lover
Are dust shields required?
Well, I guess I'm about as bad as a woman changing her mind but, I decided to go ahead and do disc brakes on the front of my '65 chevy LWB. I went with sloted and cross drilled rotors with wilwood calipers and 2 1/2" drop spindles. I have a question regarding dust shields...do any of ya'll that have done this use dust shields? They were not included in the kit I purchased so, I'm wondering if they are needed. I also purchased new stock upper and lower A-arms because the old ones were damaged. Thanks in advance for any help.
'65 chevy lover is offline   Reply With Quote
Old 03-09-2013, 05:15 PM   #2
Racer2172
Re: Are dust shields required?
They help in cooling for disc brakes
65 C-10 Times gone by(Sons truck)http://67-72chevytrucks.com/vboard/s...92#post6164692
70 C-30 Tow truck AKA Highlighter
02 Silverado 2500 HD CUCVII Tow Rig/DD
1968 C10 Project Quarantine http://67-72chevytrucks.com/vboard/s...d.php?t=804800
1980 Buick Regal Dirt Stock car
Racer2172 is offline   Reply With Quote
Old 03-09-2013, 05:20 PM   #3
Reyals Bemus
Yea I like to run em just to keep grease and road crud off the rotors.
Reyals Bemus is offline   Reply With Quote
Old 03-10-2013, 02:14 AM   #4
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
All I've ever seen them do is rust, I choose to forgo them.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 03-10-2013, 02:42 AM   #5
Slow Build
Slow Build's Avatar
I think that dust shields can be used on most spindles. That being said I don't think you can use them with CPP Modular spindles.
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
Save the dinosaurs, use synthetic oil.
Slow Build is offline   Reply With Quote
Old 03-10-2013, 03:30 AM   #6
markeb01
Senior Enthusiast
markeb01's Avatar
I'm pretty sure I left them off my 67 Chevelle when I added disc brakes to the front. I thought it looked better at the time. It also kept any small stones from getting trapped against the rotors, a problem I've had from time to time on my CRV. I don't remember the suspension being any dirtier than any other daily driven Chevelle.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 03-10-2013, 03:55 PM   #7
'65 chevy lover
Thank you to all for the replys. Went back to POL website and saw where it stated that they would only work with stock GM calipers.
"Our new dust shield-backing plates are exact reproductions of GM original disc brake dust shields found 70's and 80's Chevy and GMC trucks. These items are used when running the single piston D-52 GM caliper with factory and after market drop spindles."
I will try the shields when I put the brakes on to see for myself. If they fit correctly, I'll probably run them. Thanks again for the replys.
