Old 03-09-2013, 05:19 PM   #1
'65 chevy lover
Maximum wheel width
I am trying to determine the max wheel size I can run on my '65. I would like to go with 8" on the front and 10" on the rear. I will be using 15" wheels. I'm guessing that wheel offset will also play into this. I have 2 1/2" drop spindles on front and stock height on the rear. If I do decide to drop the rear, it will only be 1". Thanks in advance for any help.
'65 chevy lover is offline   Reply With Quote
Old 03-09-2013, 08:16 PM   #2
LVPhotos
LVPhotos's Avatar
Re: Maximum wheel width
295/45/18. Had 275/60/15. But would say 295/50/15 is about what is available in a 15. I went 18x9.5 rear 18x8 front. Backspace is a major player as rubbing will acure.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 03-09-2013, 09:20 PM   #3
gimmy 64
i have 8 inch rims all around 245-60-15 on front and 275-60-15 on the rear. if you go 10 inch rim on back 275 is probably about as wide as you can go. i have about a fingers width between tire and fender.
gimmy 64 is offline   Reply With Quote
Old 03-10-2013, 02:16 AM   #4
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
12" wide rear wheel, 325/50/15
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 03-10-2013, 04:01 PM   #5
'65 chevy lover
Thanks to all for the replys!
Old 03-10-2013, 04:50 PM   #6
donthekawguy
donthekawguy's Avatar
The PO of my truck had 15x10s on it in the back and cut the lips out of the rear fenders to make them fit. I wish he would have rolled them instead cuz now I have to fix that problem. I still have the wheels and I'm thinking about getting some tires and throwing them on.
66 shorty
donthekawguy is offline   Reply With Quote
Old 03-12-2013, 01:44 PM   #7
koda360
koda360's Avatar
Look man... easy way here.
On rear, measure from inside of bulge of tire to frame ( or what evere protrudes into wheel well farthest) CALL THAT MEASUREMENT "A"
Do same on outside of tire... CALL THAT "B"
Measure width of tire on it now, and add these three measurements togtether...
This is the widest tire that will fit period....now subtract an inch from each side for clearance...
Turn front wheels all the way to left, find closest thing that will rub on inside, measure that CALL IT "E"
Find closest thing that will rub on outside, CALL IT "F"
Do same math you did on rear...
Go to a site that gives you actual measurements of tire... this will fit. nIf you can find two tires (one front, one back) used. buy em, mount em and double check....
If your tire is closres to inside or outside, ust OFFSET to center it...
Prolly sounds like a bunch of mumbo jumbo, but try it... real easy. Selecting a wheel and tire combo is NOT splitting atoms..
1960 C-10
2000 Dakota R/T
1966 Fury I 2dr post
1984 Big Bronco
2002 Durango SLT (Bride's Ride)
koda360 is offline   Reply With Quote
Old 03-12-2013, 05:47 PM   #8
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
A picture is worth a thousand words....and truthfully picking the correct wheel and tire setup for EXACTLY what you picture isn't always easy. The "True" tire measurements vary site to site, tho I respect what you say in terms of at least getting some hard data to quantify before choosing a size.
Its also true that factoring in backspacing is often the most overlooked thing in fitting a wheel combo. With a correct backspace, you can effectively fit more tire in most scenaries, up to a maximum (which I pretty much reached, on a 12 bolt rear with trailing arms).
Old 03-12-2013, 08:00 PM   #9
'65 chevy lover
Thanks for the reply...I'll check it out!
Old 03-12-2013, 08:00 PM   #10
'65 chevy lover
Thanks for the pic!
