Old 03-09-2013, 06:59 PM   #1
Pav1
Upper Control Arm Washers
I'm replacing the bushings on a '69 Chevy C10 upper control arm. I removed the control arm and the shims and found 3 washers on each mounting stud. Would like to know if maybe some previous owner installed these washers in place of a spacer or if these washers actually belong there. To reassemble, first the 3 washers would be installed over the stud, then the shims would go between these washers and the a-arm cross shaft. Then the nuts would be installed. The question is are these 3 washers stock and should they be there? Thanks
Pav1 is offline   Reply With Quote
Old 03-09-2013, 07:50 PM   #2
valnzula
valnzula's Avatar
Re: Upper Control Arm Washers
I'm doing same and found spacers no washers
In LMC catalog shows spacers
valnzula is offline   Reply With Quote
Old 03-09-2013, 08:02 PM   #3
cdowns
cdowns's Avatar
probally added somewhere along the line in the last 40years to correct an alignment problem
Old 03-11-2013, 09:52 AM   #4
Willy Prost
Most likely yes to correcting an alignment problem.
When you have a bunch of spacers for alignment, sometimes the spacers work themselves out of the bracket.
Washers don't shimmy out , so to speak. But it makes for a problem if you need to remove a washer unless you remove the arm from the frame.
Willy Prost is offline   Reply With Quote
Old 03-11-2013, 09:59 AM   #5
SS Tim
SS Tim's Avatar
Washer are considered better in high perf. applications simply because they cannot drop out. The technique is to set the alignment with shims then replace the shims with an equivalent stack of washers. Stacking both sounds like someone chasing a problem.
SS Tim is offline   Reply With Quote
Old 04-10-2013, 01:18 PM   #6
NewType72
NewType72's Avatar
I have an issue with my left front being tucked in at the tip causing me to pull. But my shim length is maxed so I can't push out the top any further. Can I fix this by putting longer studs in so that Ivan allow the top to go out further? Or do I have a bigger issue?
Project NewType 1972 Chevy C/10 Cheyenne Super ( Daily Driven Showtruck ) http://67-72chevytrucks.com/vboard/s...d.php?t=507903
Project Great Grandpa's Legacy 1973 Chevy C/10 Cheyenne ( Current daily driver collecting big time parts ) http://67-72chevytrucks.com/vboard/s...89#post7084289
- Dylan
(209)-985-7721
NewType72 is offline   Reply With Quote
Old 04-10-2013, 02:20 PM   #7
steelhorse
steelhorse's Avatar
New type 72 it sounds like you have other problems. Maybe a bent frame or control arm. Are the springs stock or have they been cut?
steelhorse is offline   Reply With Quote
Old 04-10-2013, 02:22 PM   #8
NewType72
NewType72's Avatar
Stock 60's v-6 springs
- Dylan
(209)-985-7721
Old 04-10-2013, 02:45 PM   #9
67ChevyRedneck
67ChevyRedneck's Avatar
It's been a long time... but my suspension only needed a couple small shims to get it right... are these lowered trucks?
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
