![]() Join Date: Aug 2010
Differences in 67-72 Bench Seats
Will a 68 Bench seat bolt into a 70 truck? Will a 71-71 seat cover fit on a 68 seat? Thanks for the help.
1970 C10 to K20 conversion 1974 GMC Jimmy 1968 50th Anniversary Short Bed 1968 Chevelle 1964 Comet Caliente 1990 W250 Cummins |
![]() Join Date: Feb 2011
Re: Differences in 67-72 Bench Seats
The seats all have the same bolt pattern. If that seat you have folds forward I do not think that cover will work. If not I don't see why not.
I'm sorry I called you stupid. I thought you knew already. 67 C-20 Custom Camper 68 Nova 396 it does wheelies 2005 Buick Century the one the wife drives 1989 Toyota Tercel to drive when I can't put gas in the first 2. |
So, the 71/72's didn't fold forward?
The Older Generation
I know there are two or three different seat configurations and I think each one takes a different foam and cover. I know one is full foam and one is coil spring but not sure about the other one. I don't know what years each was available either. LockDoc
#5 | |
![]() Join Date: Sep 2009
However, I have two bench seats from different years and they have completely different bolt patterns. |
![]() Join Date: Oct 2012
ive got a 67 seat in my 70, because i like how the 67 and 68 fold forward, with a 70 cover on it, my upolstry guy just had to modify it a little so the seat would still fold forward without any problems, all the bent seats ive come across bolt in the same spot
Thanks guys. I'm looking at purchasing a houndstooth cover for a 71-72 and using it on my 68 seat is why I ask. Appreciate the help.
#8 | |
I would PM member "Truckseats" and ask him because I don't think that will work. Just my 2¢ worth. LockDoc
i have the brothers 71-72 hounds tooth seat cover on a 67 full spring back seat i recovered it myself you just cant secure the flap things on the back corvers as well if you intend to use the folding function but it really doesnt affect anything
My Patinia'd 69 69-http://67-72chevytrucks.com/vboard/showthread.php?t=517537 My RHD 68 http://67-72chevytrucks.com/vboard/s...d.php?t=594928 |
I think we will try and make it work. If not, I have a cover for a future 71/72
The bench that came in my 67 folds forward but its not even close to the correct floor bolt pattern. It appears to be a correct looking seat but is narrower then it should be.
So the PO used one existing factory hole then just drilled a single hole on the passenger side. Would it have came out of an earlier Chevy Truck? It's in pretty good shape and it would be good to know. Now the hunt is on for a Utah correct seat! Just for a clear confirmation, all bench seats have the same floor mount pattern? I saw the post with the differences in the brackets. Thanks in advance.
James B. 1967 Chevy Fleetside Shortbed 4X2 (Black & Beautiful) 1971 Chevy Fleetside Shortbed 4X4 (White & Rough) |
#13 |
Don't know if it's true or not but I heard the back rest part of a 71-72 seat is taller than the earlier seats. Anyone else heard this? I would like to put a 68 cover on a 71-72 frame.
Posted via Mobile Device |
#14 |
http://67-72chevytrucks.com/vboard/s...d.php?t=510997
Check that link as well. Lots of good info on the bracket/track differences.
-Nathan- 1972 GMC K2500 Suburban "The Project" 2013 GMC Sierra 1500 SLT Z71 "The Daily Driver" 2005 Ford F150 Lariat SCrew 2WD "The Daily Driver" SOLD 1995 GMC Sierra C1500 SLE "The Daily Driver"SOLD 2003 Ford Ranger Edge 2DSC 2WD Flareside "The Daily Driver/Project"SOLD |
