Old 03-09-2013, 08:44 PM   #1
Bhelton
Bhelton's Avatar
Porterbuilt arms
Went to install with out shims and the upper cross bar is hitting the high spot on the factory front cross member. Looking at each side I need around 1/2" of shims to clear the member and I am also trimming the edges of the member so the arms don't rub it. Kind of needing advise on this.
Bhelton is offline   Reply With Quote
Old 03-09-2013, 08:48 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Porterbuilt arms
Do you have any better pics?
Keith
Convert to disc brakes.
Old 03-09-2013, 08:53 PM   #3
lolife99
lolife99's Avatar
This bump in the crossmember bracket?
Keith
Old 03-09-2013, 08:55 PM   #4
Bhelton
Bhelton's Avatar
Section of member that needs to be notched is marked in silver
Old 03-09-2013, 08:56 PM   #5
lolife99
lolife99's Avatar
Are you sure it won't clear once you put the shims back in?
Keith
Old 03-09-2013, 08:58 PM   #6
Bhelton
Bhelton's Avatar
View of crossbar hitting member and space between cross bar and where shims would be
Old 03-09-2013, 08:59 PM   #7
Bhelton
Bhelton's Avatar
I don't have shims anymore, planning on getting new ones in the am. I figured I could bolt them up with out them
Old 03-09-2013, 10:43 PM   #8
PBFAB.COM
PBFAB.COM's Avatar
You should have plenty of room once she is aligned. Tons of these arms out there and haven't had this be a concern yet.
Feel free to get in touch with any questions.
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
