Old 03-09-2013, 09:40 PM   #1
softballnrd27
Always a work in progress
softballnrd27's Avatar
Exhaust manifold bolts broke in heads
I have 2 bolts that are broke off in the heads, 1 on each side . I tried easy outs and they broke off inside of the bolts. Now I can't get a bit to drill through them. Does anyone have any idea how I can drill these damn things out. I would rather not take the heads off if possible. I am just going to use help-coil for new threads so I just need to drill out the old bolts.
USMC Retired
Never trust a man who can't laugh at his own fart!
2010 Silverado Crew Cab
73 SWB 5.3/4l80e
Build Thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=695168
softballnrd27 is offline   Reply With Quote
Old 03-09-2013, 11:36 PM   #2
ghettoluxury
ghettoluxury's Avatar
Re: Exhaust manifold bolts broke in heads
I always put a larger nut up agianst the broken bolt and fill the hole full of weld. After it cools for a few minuates just put a socket on the nut and back it out.
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 03-09-2013, 11:59 PM   #3
softballnrd27
Don't have access to a welder.
USMC Retired
73 SWB 5.3/4l80e
Build Thread:
Old 03-11-2013, 12:50 PM   #4
farmtrucks
farmtrucks's Avatar
x2, that is they way I got 4 out of mine.
farmtrucks is offline   Reply With Quote
Old 03-11-2013, 01:21 PM   #5
harnalien
TruckincrazY
harnalien's Avatar
I had this same exact problem and the only option that worked for me short of pulling the heads was welding. Check my build thread if you want pics/tips. I rented a welder from home depot. Not sure if that's an option for you though.
My build thread - '84 2wd w/ a 6.0 swap
http://67-72chevytrucks.com/vboard/s...d.php?t=433595
harnalien is offline   Reply With Quote
Old 03-11-2013, 01:57 PM   #6
brad_man_72
the boat guy
brad_man_72's Avatar
What all others have said. Tape off the exhaust ports, take the engine down to a muffler shop with some beers and a couple of nuts to weld on.
I don't know how id get out of bed if I didn't have a welder.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 03-11-2013, 03:33 PM   #7
Jon01
Jon01's Avatar
Better get access, since ez-outs didn't work welding is the only other way to get them out without pulling the heads and taking them to a machine shop which will do the exact same thing.
Jon01 is offline   Reply With Quote
