Grill fitment question
Could anyone tell me if a grille with turn signals in the grill will fit a 72 without changing fenders and hood?? If i use my stock grille brackets?
Posted via Mobile Device |
Cluster King
![]() Join Date: Nov 2012
Re: Grill fitment question
That depend on if you are talking about a 67-68 or a 69-70.
A 69-70 will fit. Use the brackets on the 69-70. If you want it to look right, you need to change the bumper also. If you are talking about a 67-68, then the fenders, hood and radiator supprt need to be changed. Basically the whole front clip. |
Yea its a 69-70 grill. So i cant use the brackets from my 72 grill?
Cluster King
I am not sure if they are the same brackets. Maybe someone else can tell you for sure. It is possible they will work.
Cluster King
According to the LMC catalog, the left and right brackets are the same part number but the center is different from 69-70 to a 71-72.
Hope this helps. http://www.lmctruck.com/features/cb/CBGR3.htm http://www.lmctruck.com/features/cb/CBGR2.htm |
I swapped a 72 grill into my 69 years ago and don't remeber changing anything.
Troy 1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884 Big Red Dog build http://67-72chevytrucks.com/vboard/s...d.php?t=572274 |
