Old 03-10-2013, 07:59 AM   #1
KyFarm
KyFarm's Avatar
Inside door seal channel
Ok, I took off the drivers side inside door panel on my truck, it has doors from a '72, to replace some parts inside the door and line with sound deadener. The LMC book shows a foam seal (2 sided foam sticky tape) that goes on the door between the door and the panel.
There was not a foam seal when I took off the panel, but there was a plastic bag sheet glued more to the inside of that channel.
Does the foam seal go in this channel? Thanks for any help.
KyFarm's Build/Need help thread
1969 K-10, Short Step, (383HT/4L70E soon)-NP205
KyFarm is offline   Reply With Quote
Old 03-10-2013, 09:15 AM   #2
JimKshortstep4x4
Re: Inside door seal channel
The foam strip would go there. The strip is very necessary for the 67-71metal panels but I have not seen it on the 72 doors which have molded plastic panels. I am not sure if the factory put the strips on or not but it would not hurt to stick the strips on.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
