Old 03-10-2013, 01:26 PM   #1
blkcorvair
blkcorvair's Avatar
need Air Filter Part Number for Offset 6cyl air Cleaner
I put on my offset air cleaner on my 250 today with Power Brakes. Problem is the original air filter that came with my truck is not tall enough for the new air cleaner. It doesnt contact the top and bottom with the lid on. I cannot find any information on what the right filter for this setup is??? Anyone have an idea?
blkcorvair is offline   Reply With Quote
Old 03-10-2013, 01:44 PM   #2
NC67Chev
NC67Chev's Avatar
Re: need Air Filter Part Number for Offset 6cyl air Cleaner
I had the same problem when I put mine on. The filter I was told that would fit is Napa Gold 2093. However, it seemed to be about an 1/8" or so too short when I first installed it. I initially made a gasket to place under the air filter to make it fit, but I've since just removed the dense rubber gasket from the lip of the cover and replaced it with some soft foam gasket material. It now fits great.
1967 Chevy C-10, 250 L6, Powerglide, 3.73, SWB, Fleetside
Upgrades: Power steering, Offset air cleaner, Rear Sport bumper, 3 point safety belts, HEI, -1/-2 springs, 16x5 wheels, McGaughy's disc brake conversion, Sway bar
NC67Chev is offline   Reply With Quote
Old 03-10-2013, 03:05 PM   #3
blkcorvair
blkcorvair's Avatar
Thanks Ill give that a shot!!
Old 03-14-2013, 03:17 PM   #4
blkcorvair
blkcorvair's Avatar
Thank you that filter number was indeed correct!
