Old 03-10-2013, 05:24 PM   #1
Sloan66
Fuel Pump Question
Do they make a fuel pump with inlet line that is 5/16? The one on my truck is 3/8 but the fuel lined from tank is 5/16
Sloan66 is offline   Reply With Quote
Old 03-11-2013, 10:29 AM   #2
Shyguy
Junior Member
Shyguy's Avatar
Re: Fuel Pump Question
Which engine do you have?
The fuel line from my tank was a 5/16", but when we put the V-8 in the truck we changed out the sending unit and the fuel line to 3/8".
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 03-11-2013, 11:06 AM   #3
dmw319
Could you just use a brass adapter?
1970 Chevy C-10 Stepside
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=528167
dmw319 is offline   Reply With Quote
Old 03-11-2013, 05:54 PM   #4
Shyguy
Junior Member
Shyguy's Avatar
You are right a brass adapter would work, but since we put a mild built 454 in my truck I thought it would be better to go with 3/8" fuel line.
Old 03-11-2013, 08:28 PM   #5
68gmsee
Active Member
68gmsee's Avatar
You could get brass adapters or you may be able to force the hose over it. You can also get a fuel pump for a six?? They used the smaller fuel lines.
Pic from autozone. They're about $20.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 03-11-2013, 09:48 PM   #6
longbed67
longbed67's Avatar
Get an adapter... they are less than $5 retail.... and I may be wrong but a L6 pump wont work correctly on a v8 as I do know that the v8 pumps wont work on the L6
Adam
My 1967 C10 - Turbo 250 Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=485843
(608) 214-8706
longbed67 is offline   Reply With Quote
