Old 03-10-2013, 06:39 PM   #1
Dylan86
Dylan86's Avatar
mech fuel pump leak oil?
Finally got my truck road legal, took her for a long drive the other day, opened up the hood to find a leak of engine oil on the front mech pump side of the block. i also found some coolant. it is a brand new engine. the coolant was from the lower rad hose, so i replaced it, thats all good now. i installed new gaskets for the fuel pump, cleaned it all off and went for another spin, still leaking, but i cant replicate it when in the shop.... the only thing that makes sense is that the fuel pump is leaking oil out the body or something? is that possible? anyone seen something like this? any help would be great.
Dylan86 is offline   Reply With Quote
Old 03-10-2013, 07:54 PM   #2
ray_mcavoy
Re: mech fuel pump leak oil?
On a lot of blocks there are two threaded holes on the front over near the fuel pump area. One of them is open into the fuel pump pushrod bore and can be a source of the type of leak you're experiencing.
To fix it, simply put a 3/8"-16 bolt in that hole with some thread sealer. Use a short bolt (only about 1/2" to 3/4" long) so it doesn't go in deep enough to hit the fuel pump pushrod.
ray_mcavoy is offline   Reply With Quote
Old 03-10-2013, 08:26 PM   #3
wraprail
wraprail's Avatar
I agree with ^ Ray 100% and on a new motor for sure. It could also be the fuel pump itself. There is a hole in side of the pump ( weep hole?) and mine was dumping oil out this hole. Pull it off and turn it upside down. If oil comes out that hole replace it.
wraprail is offline   Reply With Quote
Old 03-10-2013, 09:27 PM   #4
motornut
78K & 79C Jimmys
motornut's Avatar
seen the pump go like that too
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 03-10-2013, 09:36 PM   #5
Hubscrub
Cruzin
Hubscrub's Avatar
good chance this is it, easy to check and fix.
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline   Reply With Quote
Old 03-10-2013, 09:57 PM   #6
68gmc780
Mechanical pumps can leak oil externally,fuel externally and internally.Used to see it all the time in the 80's when I started wrenching.
68gmc780 is offline   Reply With Quote
Old 03-10-2013, 11:03 PM   #7
Dylan86
Dylan86's Avatar
hey thanks everyone, that bolt missing is exactly what it was! found this picture after all you said, to help anyone else whos having this issue.
Old 03-11-2013, 12:01 AM   #8
68gmc780
Oh yeah! Now i remember that hole! It can be used (very gently) to put a longer bolt in to lock the fuel pump rod in place when you change the fuel pump.Usually it is covered by brackets and other obstructions so that it becomes useless for that procedure.
Old 03-11-2013, 10:46 PM   #9
Dylan86
Dylan86's Avatar
Ok i noticed at idle that hole is sucking allot of air in. when i put the bolt in the pump gets really noisy? is this ok? it shouldnt be this loud?
