03-10-2013, 06:41 PM | #1 |
ls wiring
Ok i got my psi conversion harness in and wired up but im not getting any power in my cab. Any ideas? Also which wires can i delete since i.wont need a voltage regulator anymore
Posted via Mobile Device |
03-10-2013, 07:19 PM | #2 |
Re: ls wiring
Got it lined out
03-10-2013, 08:08 PM | #3 |
Re: ls wiring
How do you like your harness? I've got one on order or my 6.2 Swap. Should be here next week. I'm getting kind of anxious.
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
03-10-2013, 09:01 PM | #4 |
Re: ls wiring
Really good quality. You will be pleased.
03-11-2013, 12:55 AM | #5 |
Truck and auto performance nut
Re: ls wiring
my cab wiring is my old/existing wiring while the new LSx runs off a Painless "circuit boss" I added to my electrical system to give me some "new" circuits w/o loading down the OEM wiring.
Circuit Boss is bottom right near filter. Provides 4 "switched" circuits and 3 "battery or, always on" circuits. Powered direct to battery, activated via relay and 1 wire off OEM fuse panel to "switched on/off". NEW "custom harness" power/relays
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
