Old 03-10-2013, 08:38 PM   #1
six8burban
4L60E Torque converter ?'S
Ok my engine wouldn't start until I disconnected the flywheel from the converter......dropped the trans and converter won't make a full turn with out binding and then unturnable? I don't think it's the trans because outter shaft spends fine without converter connected. 6.0 and trans was purchased from a salvage yard and has been sitting for about seven years till recently. I was told engine and trans came out of a 2004 chevy truck. If it is the stall any recommendations for new one?
six8burban is offline   Reply With Quote
Old 03-10-2013, 09:03 PM   #2
clinebarger
Re: 4L60E Torque converter ?'S
Something wrong with the front pump.
clinebarger is offline   Reply With Quote
Old 03-10-2013, 09:08 PM   #3
six8burban
I'm sorry do you mean converter?
Old 03-10-2013, 09:13 PM   #4
six8burban
http://www.jegs.com/i/TCI/890/242936...tId=746227#%23
Will this one perform better than stock?
Old 03-10-2013, 10:12 PM   #5
six8burban
.....or how about this one?
http://m.summitracing.com/parts/hup-gm22tow
Old 03-10-2013, 10:25 PM   #6
six8burban
Nope I like this one!
http://www.jegs.com/i/Hughes+Perform...-25EL/10002/-1
Old 03-10-2013, 11:42 PM   #7
mattcrp1
mattcrp1's Avatar
Your converter may not be fully seated in the pump.
mattcrp1 is offline   Reply With Quote
Old 03-11-2013, 12:06 AM   #8
Kim57
Kim57's Avatar
Sounds like the front pump is broken.
Those are the same symptoms mine had and it was the front pump.
Here's a pic of the pump and it's insides.
There's not a lot of moving parts inside it. They're easy to break if the torque converter is left attached to the flex plate when separating the trans and engine. I had mine rebuilt with a 13 vane pump.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 03-11-2013, 02:27 PM   #9
six8burban
Kim
...and how much did this cost?
Old 03-11-2013, 07:27 PM   #10
clinebarger
You wont know untill you pull the pump, & separate the half's.
All '98 & up 4L60E's have 13 vane rotors in the pump. If you need a pump...'98-'04 will fit, The '05 & up like Kim57's pump will not work.
Old 03-11-2013, 09:46 PM   #11
Kim57
Kim57's Avatar
They re-built my pump for $100.00. A re-manufactured one would have been twice that because it included a new stator.
While I have it apart for the pump I'm putting in a shift kit and aluminum pistons in the actuators. I guess the plastic ones have been a problem in some transmissions.
Kim
My build thread
Old 03-11-2013, 09:52 PM   #12
six8burban
I stopped by a couple of trans shops today and one shop wanted 1,280 to rebuild entire trans and other shop wanted 150 just to replace pump and 3rd shop wanted 400 to install used pump and go over everthing else?
Old 03-12-2013, 12:20 AM   #13
Kim57
Kim57's Avatar
With the pump shift kit and all the gaskets and seals I have a little over $300.00 in mine and I'm doing the labor myself.
My pump is all new inside and I did upgrade the pistons which I would recommend.
It all comes down to how confident you are in the rest of the trans being in good shape as to which way will be best for you.
I'm taking a chance on mine being good. The fluid didn't smell burned although it was a little discolored.
Good luck with it.
Kim
My build thread
Old 03-12-2013, 02:42 AM   #14
six8burban
Good luck with it.
Kim
...is shift kit part of pump, u have a part #? I did see a couple of rebuilt 13 vane pumps on eBay, or can I get mines rebuilt to a 13 vane? How do you like the shift kit and how does it differ from stock?
Old 03-12-2013, 11:57 AM   #15
Kim57
Kim57's Avatar
It's a TransGo kit #SK 4L60E series L for 1993-2010 transmissions.
It has parts for the valve body and pump (mainly springs) and detailed instructions on what to do. There are some changes made to the separator plate also (enlarging some holes that they supply the drills for).
Says "This is not a do it yourself kit" but I never let that stop me.
The instructions are very complete and I think it can be done by some one with mechanical ability. They also have a tech line that is pretty good.
The kit was just over $50.00
It's supposed to make the shifts shorter and cure some of the factory problems with these transmissions.
Kim
My build thread
Old 03-12-2013, 12:06 PM   #16
six8burban
Kim
Did it cure any problems?
Old 03-12-2013, 07:02 PM   #17
Kim57
Kim57's Avatar
I haven't got it back together yet.
It's going in my 57 project which isn't even on the road yet so it will be a while before I know how it all turns out.
Kim
My build thread
Old 03-12-2013, 08:49 PM   #18
clinebarger
All '98 & up 4L60E pumps are 13 vane. So this isnt really an upgrade. In fact your pump will have 13V stamped on it.
The SK-4L60E shift kit is great....I use them on All 4L60E's for under 375hp.
The most noticable thing it does is eliminate the "Slide-Bump" 1-2 shift.
At the very least Put 3-4 Clutches & a "Borg Warner" Forward Sprag in while it's apart!!!!!
8 or 9 3-4 frictions...Alto A74100CPK/057757B.
Forward Sprag...Borg Warner 29236AM.
Alto 3-4 vs Stock 6 friction stack.
Old 03-12-2013, 09:46 PM   #19
Kim57
Kim57's Avatar
Can these changes be made without special tools?
Would they be an upgrade for my 4L70?
I know it's just a little stronger 4L60 but it's what came with my LS2.
Kim
My build thread
Old 03-12-2013, 10:29 PM   #20
clinebarger
Kim
Yes, You can do 3-4's & a sprag change without special tools.
4L65E & 4L70E use a 7 friction 3-4 stack, Adding frictions is an upgrade.
Old 03-12-2013, 11:25 PM   #21
Kim57
Kim57's Avatar
Cool, thanks.
Kim
My build thread
