Old 03-10-2013, 11:13 PM   #1
DBear
DBear's Avatar
Corp 14FF U bolt question
Does anyone know if you are able to change the style of U bolt and spring plates on a 73-91 K30, going from the under-the-axle spring plate to the style on top of the spring?? Basically going from square style to round style. I thought I read somewhere you couldn't on a stock set up, but not sure???? Thanks in advance.
DBear is offline   Reply With Quote
Old 03-10-2013, 11:36 PM   #2
dieseldawg142
dieseldawg142's Avatar
Re: Corp 14FF U bolt question
got sick of rusted u-bolt plates, just ordered the u-bolt flip kit from ORD.
dieseldawg142 is offline   Reply With Quote
Old 03-10-2013, 11:43 PM   #3
DBear
DBear's Avatar
that is what I was looking at, but the website said that on 1 ton's the truck would have to have a lift or the plates would hit the frame....which I am confused because I don't see anyway it could hit the frame....???????
Old 03-10-2013, 11:50 PM   #4
Rubble
I got 2 3/4t with 14bolt ff,there is lots of room between the plates and frame.Should be the same for 1 tons?? I will find out in a bit,need to put new springs on my crew & the plates are going on the top.
1977 Chev C30 454/465/14ff DRW
1974 Chev C20.350/465/14ff
" Rock n Roll ain't noise pollution"
Rubble is offline   Reply With Quote
Old 03-10-2013, 11:55 PM   #5
dieseldawg142
yeah, your right, i guess i did'nt think about that- i have a 8" lift. also have airbags brackets, but i have room for them. you would think if clearances are that tight on stock susp. that airbags would'nt fit either, but they do. the a.bag brackets are 2 1/4" tall & they dont contact anything. heck, should only have about 1 3/4" of u-bolt & nut sticking up. when mine get here i can post pic's, but they probably wont tell you anything if your susp. is stock
Old 03-11-2013, 12:16 AM   #6
Rubble
I will try to get some pics,maybe tomorrow...
Old 03-11-2013, 12:20 AM   #7
DBear
DBear's Avatar
Trying to picture where the springs set under the frame....but it seems that they sit outside the frame rails??? If they do, how the heck would the interfere with the frame itself???
Old 03-11-2013, 01:10 AM   #8
dieseldawg142
they do sit outside. it's been 7 or 8 yrs since i lifted my crew, so i dont remember how close to the frame. but look at the pic, dont see how they'ed hit either. look at the size of the airbag mount. the old fellow i bought it from (stock susp.) hauled a huge 12 ft camper on it with bags.
Old 03-11-2013, 02:02 AM   #9
argonaut
argonaut's Avatar
The spring hangers on a 3/4 ton are different from a 1 ton. On the one ton they sit closer to the side of the frame, and the spring pad spacing on the axle is also narrower. For this reason when the suspension flexes the upper spring plates would come close to the frame.
Hope this helps.
Jason M. @argonaut62
1972 K5 Blazer CST, Turquoise
1966 K20 Short Fleet Pickup, Big Ugly
1964 C10 Short Fleet, Gertrude
2001 Porsche 911 Carrera
1996 Ford Bronco XLT
1980 Jeep Wagoneer
2008 Honda CBR1000RR
2005 Honda RC51
1981 Honda CB750C
No dis-assemble Johnny Five! No dis-assemble!
argonaut is offline   Reply With Quote
Old 03-11-2013, 02:23 AM   #10
DBear
DBear's Avatar
Here is a picture I found on another thread......seems like it has plenty of room. This picture is of a 87 K30......It is in the first post on the first page...
http://coloradok5.com/forums/showthread.php?t=297031
Old 03-11-2013, 02:56 AM   #11
argonaut
argonaut's Avatar
Hmmm, it may be a DRW vs SRW thing. The K30 I was referencing was a DRW.
1980 Jeep Wagoneer
2005 Honda RC51
1981 Honda CB750C
Old 03-11-2013, 04:04 AM   #12
dieseldawg142
yup, that is more than enough.i'm thinking if the u-bolt plate was wide enough to hit the frame, it would contact the bump stops first. i just cant see it being that wide, they should'nt be much if any wider then a.bag mounting plates, & p.o. of my crew said he had no probs., nor have i ever found any kind of marks or contact on my frame (before i lifted it, or after)
Old 03-11-2013, 03:41 PM   #13
Rubble
Hope this helps.
Ya,both mine are SRW,maybe from older 3/4 T also.I went thru this dually to single wheel swap a year ago too also,forgot about it already!!
Old 03-11-2013, 07:23 PM   #14
obijuan
remove. replace. done.
obijuan is offline   Reply With Quote
