Old 03-11-2013, 12:24 AM   #1
tim21391
tim21391's Avatar
what is this and its function?
what is this part and what exactly does it do... dont laugh but to me it looks like an egr valve but i doubt a 72 402bb has one being that old haha...its diaphragm operated off vacuum off the carb.. it runs smooth with it unhooked and sucking vacuum with it uncapped.. hook it back up you can see it function til its sucked shut and then it sounds like the motor is "cammed" i assume since its there it needs to be hooked up.. truck runs fine just curious to what it is
thanks
tim
1972 C-10...402/400..flowmaster 40 series
1967 Mustang 347 stroker/C-4
1966 Mustang 289/3-speed
2013 Mustang V6/6speed w/300 ponies
I may be 23, but i sure do knows 67-72s are sexy!
Its not MPG its smiles per gallon!
build started 11/25/08
build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796
tim21391 is offline   Reply With Quote
Old 03-11-2013, 12:53 AM   #2
LODI3QTR
LODI3QTR's Avatar
Re: what is this and its function?
It's the vacuum diaphragm to open the vent on an AC cab..........
LEFT LANE IS FOR PASSING!!!! SLOWER TRAFFIC KEEP RIGHT!!!!
My C20 & Cars... http://67-72chevytrucks.com/gallery/...&ppuser=111212
LODI3QTR is offline   Reply With Quote
Old 03-11-2013, 01:49 AM   #3
SS Tim
SS Tim's Avatar
That is for the air recirculation door. The air inlet is from the right kick vent. If you don't have the factory manuals then download them here, as there is a wealth of information.
http://67-72chevytrucks.com/vboard/s...d.php?t=558016
SS Tim is offline   Reply With Quote
Old 03-11-2013, 05:49 AM   #4
daves72C10D
daves72C10D's Avatar
Not to hijack the thread, mine is sheared off at the firewall. I have not looked at a manual, how hard is it to fix?
1972 Custom 10 Deluxe- original paint, interior- 72k miles
http://www.cardomain.com/ride/2466316
Cheap, Fast or Good. Pick any two.
1990 Eagle Talon AWD
1991.5 W250 CTD
1992 Cushman Truckster- Haulster
daves72C10D is offline   Reply With Quote
Old 03-11-2013, 06:27 AM   #5
Andy4639
Old member
Andy4639's Avatar
Cool Re: what is this and its function?
I did away with mine and sealed it up. The AC works fine as does the heat.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 03-11-2013, 07:51 AM   #6
SS Tim
SS Tim's Avatar
You have to pull the cowl panel to access it. See page 1A-35 of the 72 service manual linked above.
Andy, It is not a redundant part or function. If you sealed the valve opening up all you are doing is recirculating cab air all the time.
Old 03-11-2013, 09:51 PM   #7
tim21391
tim21391's Avatar
ok sounds good thanks guys
