Old 03-11-2013, 12:43 AM   #1
underton
Shifting problem in manual 3 speed
I just bought a 68 gmc pickup with a inline six and a three on the tree. It has a peculiar problem while trying to shift between the back two gears (second and third) and the closer gears (first and reverse). It's hard to pull back into the closer gears, especially when its cold outside. I don't have much experience with Chevys and gmc, so any advice would help.
Thanks in advance for any help.
underton is offline   Reply With Quote
Old 03-11-2013, 10:13 AM   #2
Shyguy
Junior Member
Shyguy's Avatar
Re: Shifting problem in manual 3 speed
One of the problems with these types of shifters is all the bushings in the linkage wear out and cause for difficult and some times hung up shifting.
Check all the bushings and lub what you can.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 03-11-2013, 11:03 AM   #3
LockDoc
The Older Generation
LockDoc's Avatar
Another problem is the shift tube inside the column, it gets dry and/or the old grease gets stiff. Put the shift lever in neutral and spray some PB Blaster, Liquid Wrench, or something similar (not WD-40) into the steering column, where the shift lever goes in. Don't be afraid to give it a good dousing. After you spray it pull the shift lever up toward you and push it back down toward the dash. The knob should move up and down a couple of inches. Do this 4 or 5 times. This will help free up any sticking in the shift lever tube. The reason the shift lever moves up and down is to engage the two different gates, one for first and reverse and one for second and third.
As Shyguy says, spray the linkage and levers at the bottom of the column and trans linkage under the hood.
LockDoc
Leon
Old 03-11-2013, 11:37 AM   #4
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
All you need to know to get it to shift like new.
http://67-72chevytrucks.com/vboard/s...d.php?t=215307
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 03-11-2013, 12:48 PM   #5
clemsonteg
I followed this and mine improved.
I adjusted the linkage and ordered 2 of these for the shift tube:
http://www.classicparts.com/1947-76-.../#.UT4KADcU2o8
And 4 of these for the linkage at the trans, it says only 2 but I think its wrong because what was left of mine there were 4:
http://www.classicparts.com/1960-76-.../#.UT4KOTcU2o8
I also got 2 new clips at for the trans linkage:
http://www.classicparts.com/1960-72-.../#.UT4KYzcU2o8
I haven't tried spraying lube inside the cab, I will need to try that. One problem I have is all the slop at the shifter itself, it has a new pin but I think the internal collar has seen better days. When the trans is in gear I can move the lever 2 inches up and down without effecting the linkage and everything else is adjusted I believe. I haven't found any replacement parts (I believe it is the shift socket?) for that so I will just live with it.
clemsonteg is offline   Reply With Quote
Old 03-11-2013, 02:26 PM   #6
LockDoc
LockDoc's Avatar
I think you are right. The only cure for that is to replace the collar that the shift lever attaches to.
LockDoc
Leon
Old 03-11-2013, 03:47 PM   #7
cdowns
cdowns's Avatar
all great ideas
overlooked alot of times is sagging and rotted body mounts causing misaligned shifting linkages in older vehicles
Old 03-11-2013, 09:51 PM   #8
clemsonteg
LockDoc
Not to thread jack, but any idea where that part can be purchased?
Old 03-11-2013, 10:35 PM   #9
LockDoc
LockDoc's Avatar
Salvage yard or the parts board on here. There are a lot of guys on the parts board parting out trucks. I wouldn't think it would be too hard to find one. You can't post a wanted to buy but if you find one on the parts board you can buy it. You might try sending a PM to Randy, (Member "Teeitup"). he has a lot of posts on the parts board.
LockDoc
Leon
