Old 03-11-2013, 07:41 AM   #1
dubie
dubie's Avatar
Radiators
I'm going to be in need of a rad here soon, where's the best place to get a factory replacement? I don't want to use an aluminum one on this truck.
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline   Reply With Quote
Old 03-11-2013, 12:24 PM   #2
mr48chev
mr48chev's Avatar
Re: Radiators
If you can afford it Walker has some of the best but the price is up there pretty high.
If you have a real good radiator shop close by you might want to ask about having them modify your tanks and put a new core in your old radiator. That isn't inexpensive either but it's an option that is available. That is a pretty good possibility due to where you live. I'd suspect that there is a radiator shop that repairs ag, truck and heavy equipment radiators in that area that could handle a pickup radiator and know what they were doing.
My ongoing truck projects:
Old 03-11-2013, 02:14 PM   #3
dubie
dubie's Avatar
Re: Radiators
unfortunately the closest rad shop is a 4 hour drive from us. We used to have one in a neighboring town but it closed down a few years ago. Maybe I'll rob the one out of my wife's 58 and replace hers with a new one when the time comes
Old 03-11-2013, 04:26 PM   #4
oldcouple
oldcouple's Avatar
Re: Radiators
I had the original, which was for a six cylinder 56, rebuilt by a shop into a four core copper. Cost a fortune, never worked right, kept coming apart and they fixed it, the it leaked. So just bought a three core aluminum off ebay, it works better, looks better and cost half what the rebuild did.
Retired and too busy to work.
oldcouple is offline   Reply With Quote
Old 03-11-2013, 06:02 PM   #5
mr48chev
mr48chev's Avatar
Re: Radiators
This one is aluminum but I like what they have to say. I've been looking into their radiator that fits my 48. http://www.ebay.com/itm/Chevy-1955-1...ba8f08&vxp=mtr
Old 03-11-2013, 09:06 PM   #6
spinned
spinned's Avatar
Re: Radiators
Take your old one to the radiator shop and ask to have it re-cored with a 4-core in copper. They will keep the top brass and frame and gut the rest and then install a nice new modern copper insert. (about $500).
spinned is offline   Reply With Quote
Old 03-11-2013, 09:19 PM   #7
Chevette
Chevette's Avatar
Re: Radiators
I've got one you can have. I won't have time to package it until late next week though. It worked very well and when I removed it from my 56, I stored it in a safe place, so it should be good. I bought a big aluminum rad so I don't need it anymore. Get back to me if you want it.
56 Chevy PU
http://67-72chevytrucks.com/vboard/s...d.php?t=531955
Question: Know how to sell your truck for $50,000?
Answer: Spend $100,000 building it.
Chevette is offline   Reply With Quote
Old 03-11-2013, 09:40 PM   #8
mr48chev
mr48chev's Avatar
Re: Radiators
His problem with that Spinned is that he is further from a radiator shop than I am from you. Not quite as bad as running from Burns to Portland for a radiator but close.
Old 03-12-2013, 12:26 AM   #9
torchlight
torchlight's Avatar
Re: Radiators
I just ordered a unit from US Radiator for my 53.
torchlight is offline   Reply With Quote
Old 03-12-2013, 07:03 PM   #10
Chevette
Chevette's Avatar
Re: Radiators
Dubie: Here are some pics. I realized after I dug it out of the rafters, that it isn't original spec. To bad, because there isn't a bent fin on it. Just a bit dirty on the outside.
56 Chevy PU
Old 03-27-2013, 12:23 PM   #11
dubie
dubie's Avatar
Re: Radiators
sent you a PM this morning on this rad
Old 03-27-2013, 06:26 PM   #12
Speedbumpauto
Speedbumpauto's Avatar
Re: Radiators
If you're looking on E bay, search for an outfit called Bryce Thomas Radiators. I bought one from them with the stamped tank and two rows of 1 1/4" tubes. Mine came with a 16" Marydine fan and an aluminum shroud. It fit perfectly and these guys make all their own stuff in house unlike most of those sellers who buy the offshore stuff and re-sell it. They're not the cheapest but they're good.
Speedbumpauto is offline   Reply With Quote
Old 03-27-2013, 07:12 PM   #13
mknittle
mknittle's Avatar
Re: Radiators
That's good to know thanks!
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 03-27-2013, 09:10 PM   #14
GMtrucknut!!
GMtrucknut!!'s Avatar
Re: Radiators
Well after working in a radiator shop for a number of years I can tell you that the original copper tanks will become brittle with age . The thermo cycles involved are astonomical ,every spot where the tank has been formed by the stamping process eventually will start to crack due to stress from that process. So recoring is sometimes throwing good money away.
The other thing with radiators is the original copper/ brass type are more efficient but more expensive due to cost of raw materials.The reasoning behind the use of aluminum isn't better cooling but weight saving and inexpensive aluminum versus expensive copper.The copper radiators are roughly 25 percent more efficient.
Walker ,Modine,US radiator and a couple of other manufactors of oem style radiators are still available. I would try to avoid most of the inexpensive radiators from the aftermarket as even though they boast of 3 and 4 row applications the thickness of the core still hasnt changed.This means that the square inches of cooling surface isnt really and better than an original.
GMtrucknut!! is offline   Reply With Quote
