Old 03-11-2013, 12:46 PM   #1
Buzzman
Buzzman's Avatar
Bad starts when warm...heat soak? Carb?
Hey there,
(350 with Edelbrock intake and original 4bbl Q-jet)
Having some issues starting when the motor's nice and warm. For instance, when driving around all day, running errands, if I stop for 15 minutes somehwere and come out, the truck has a hard time starting. It turns over, but I have to give it some gas to get going. In the morning, or after sitting for a while (hour-plus), it fires right up.
I've done a little research and it seems that it might be starter heat-soak, as the exhaust downpipe does run pretty close (ramhorns). A mini starter/heat shield might fix this. The other possiblity would be something with the carb - it almost feels as if it's flooded, or the gas is getting too hot from the intake -some folks have mentioned a carb spacer to help with this.
Anyhoo, sorry for the long post. Any tips? Thanks.
79 C10 Cheyenne SWB Daily Driver
Buzzman is offline   Reply With Quote
Old 03-11-2013, 03:36 PM   #2
INSIDIOUS '86
INSIDIOUS '86's Avatar
Re: Bad starts when warm...heat soak? Carb?
Edelbrock afb carbs are notorious for having hot start issues. Wouldn't surprise me if that was an issue
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 03-11-2013, 07:07 PM   #3
Buzzman
Buzzman's Avatar
I've heard that, too, but mine's the stock Q-Jet. The more I read, it sounds like I should just try a spacer.
Anyone else?
Old 03-11-2013, 07:13 PM   #4
hotstuff
the alum intake transfers the heat to the carb , so you are right on , with the spacer
hotstuff is offline   Reply With Quote
Old 03-11-2013, 07:46 PM   #5
99monte
Heat soak of the starter will give you a hard,laboring crank ,definitely sounds fuel related.Had that problem on a lot of passenger cars in the 80's when they started introducing ethanol blended fuel,lowered the boiling point I think,fuel would boil in the carb,spilling over into the intake,the thing would be flooded and the carb would be empty till the fuel pump caught up.
99monte is offline   Reply With Quote
Old 03-11-2013, 07:51 PM   #6
Damon23
Damon23's Avatar
Mine has the same issue. I'm running a edelbrock. I was told it is a combination of the new crappy fuels evaporating faster in the carb and the heat off the intake. My friend said a aluminum intake with a spacer is the way to go. The 80 rally sport camaro had a edelbrock aluminum intake, carb and 1in spacer and never had the issue my truck has with its factory intake. That swap is on the list.
Experience is something you gain when you didn't get what you wanted in the first place.
No great defeat was ever just possible in the beginning.
Damon23 is offline   Reply With Quote
Old 03-11-2013, 07:58 PM   #7
Buzzman
Buzzman's Avatar
Right, it's gotta be a combination of the stock Q-Jet and the aluminum intake. I think the aluminum must conduct heat a little better than the old cast-iron. Spacer it is... Thanks guys.
Old 03-11-2013, 08:27 PM   #8
wiskers
wiskers's Avatar
Timing might be set to far advanced, might bump it back a lil? Just my .02 cents
wiskers is offline   Reply With Quote
Old 03-11-2013, 08:46 PM   #9
Pork Chop
I have the same problem,edelbrock performer intake and edelbrock 600 cfm. Should I add a spacer?
Pork Chop is offline   Reply With Quote
Old 03-11-2013, 09:32 PM   #10
thesickc10
x2
1985 c10 355 th350 (working on 4 speed conversion to super t10)
1979 camaro 358 super t10
2003 f250 superchip slp exhaust
thesickc10 is offline   Reply With Quote
Old 03-12-2013, 01:16 AM   #11
Duster
Duster's Avatar
Do you have an electric choke on it? If you do, I will bet it is engauging when it isn't supose to. The choke will also keep the secondarys from opening, so after you start it when it is warm, floor it and see if the big boys dump.
Duster is offline   Reply With Quote
Old 03-12-2013, 04:27 AM   #12
piecesparts
Parts and more parts
piecesparts's Avatar
Aluminum intakes and whether it be an Edelbrock carb or another brand, there are some issues with the fuels of today. The amount of alcohol within the gas causes it to evaporate quickly on a hot day. If your fuel line is metal and it runs close to the head or upper radiator hose, that will also cause vapor lock issues. If your fuel pump does not have a return line to the fuel tank, there is another place the fuel will boil away.
I put a phenolic spacer under my carb, I made sure my fuel line was clear of all heat soak areas, and I put a new bottom plate on my edelbrock fuel pump to get the extra openings and made sure that my return line to the tanks was working. It solved the majority of my heat/vapor lock issues on my stroker engine.
Frank
piecesparts is offline   Reply With Quote
Old 03-12-2013, 01:54 PM   #13
Buzzman
Buzzman's Avatar
Choke is the stock hot-air version attached to the intake - I think it's working fine.
I think I'll check the timing, put the spacer in, and make sure all lines are clear of the exhaust and whatnot. Just put a new fuel pump in, so the return line should be good. Thanks for the help everyone!
Old 03-12-2013, 05:01 PM   #14
slugish
Slugish
Is a phenolic spacer made of some sort of wood . I have a wooden spacer on mine & was told they did the best job of heat retention . Just cant remember if they said it was phenolic or not , Will
slugish is offline   Reply With Quote
Old 03-12-2013, 05:03 PM   #15
Buzzman
Buzzman's Avatar
Phenolic is some king of high-density, space-age plastic. Apparently it's head resistant and doesnt shrink or warp. We'll see!
