Old 03-11-2013, 03:17 PM   #1
bojak
bojak's Avatar
Lug nuts?
Was wondering if someone had this info in there memory banks. I have an 89 V3500 with d60 front. We will assume the that the wheel studs are original. I bought a set of 2004 8 lug takeoffs with center caps to go on it. what size lug nuts inner and outer thread do i need to find to make this work? Guy at parts counter at the local chevy dealer says that his computer doesn't show anything, so that truck must not have ever existed. i'm hoping none of you work there or i am in trouble.
bojak is offline   Reply With Quote
Old 03-11-2013, 04:47 PM   #2
b454rat
Re: Lug nuts?
They don't make a factory lug nut that will have the external threads, in standard thread. They obviously make them in metric in 88-up. Go on evilbay and search for conversion lugnuts, you need 9/16".
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon 350/4L60 6" SAS
Old 03-11-2013, 05:15 PM   #3
zaccaglin
zaccaglin's Avatar
Re: Lug nuts?
Here's the ones I plan to buy.
32 LUG NUTS DUAL EXTERNAL THREAD 9/16-18 8 LUG NUTS CHEVY, GMC 1971-1988
http://bit.ly/XDYILa
Zaccaglin
1998 Chevrolet C1500 Ext. Cab 350
Former Rig:
1985 Chevrolet K20 Suburban 6.2L Detroit/TH400/NP208
zaccaglin is offline   Reply With Quote
Old 03-11-2013, 05:48 PM   #4
bojak
bojak's Avatar
Re: Lug nuts?
Thank you very much. That helps a bunch.
Old 03-11-2013, 08:57 PM   #5
88Jimmy4x4
88Jimmy4x4's Avatar
Re: Lug nuts?
ya that guy is only one I know of selling the conversion dual thread lugs
2008 Silverado Z71 RCSB
1991 GMC Jimmy 4x4
1976 GMC Sierra C15 SWB
88Jimmy4x4 is offline   Reply With Quote
Old 03-11-2013, 09:34 PM   #6
zaccaglin
zaccaglin's Avatar
Re: Lug nuts?
No problem, I've messaged him numerous times, he warranties and stands by what he sells. He says there the same material as what the OEM would be if offered in that configuration.
Zaccaglin
Former Rig:
Old 03-12-2013, 12:59 PM   #7
bojak
bojak's Avatar
Re: Lug nuts?
I should have a set in a big brown truck by now. Thanks again.
Old 03-12-2013, 02:40 PM   #8
James McClure
One shot, one kill.
Re: Lug nuts?
I got those nuts off of Ebay too and they worked the nuts. I put 89 wheels from my kids truck on mine and needed them. Had to cut the center out of the 2 front hub covers though to get to the hub locks. Pictures on here someplace, but don't know where. jim
1984 K20 350M engine with 465,000 miles. Well, it's finally done!! Almost 2 years of work, but it was really worth the effort. Little stuff left to do is mount winch, wet sand & buff out and build belly pan\running boards. Body work takes lots and LOTS of beer!!!! God, Guts and Guns made America and God, Guts and Guns will preserve it! The worst thing you could do is get into my sights, but that don't matter, you'll never know it, cause you'll never hear the shotJim or Paladin whichever you choose.
James McClure is offline   Reply With Quote
Old 03-12-2013, 04:33 PM   #9
bojak
bojak's Avatar
Re: Lug nuts?
yeah you are actually the person i got the idea from. i saw a photo of your truck and thought it was a great idea. I like the newer steel wheels over putting alloys, or aftermarket wheels on. I have the painted ones and i am trying to decide if i want to leave them the light silver they a;ready are (and less work for me) or paint them a dark pewter like what is on my truck now, or black. Still not sure which way i am gonna go yet other than they are going on soon.
Old 03-14-2013, 08:40 AM   #10
bojak
bojak's Avatar
Re: Lug nuts?
Ok so was checking things out last night and my freind, disappointment showed up. My truck as d60 front axels. I knew to make the center caps work i would have to whole saw the front center caps to allow them to pass through. Due to the diameter of the d60 hub i will probably have to remove too much of the center cap for it to work. It is around 4.5 inches and that is as big as the narrowest face section of the center cap. I gt a good deal on them and if i cant use them they will be wasted anyway so that being the case i am going to drill thiem and see how it comes out. I am pretty sure it will look junky. If it doesnt work then i am painting the wheels black and using chrome acorn style lug nuts with hopefully a chrome low pro center cap on the rear wheels to mirror or simulate the protrusion of the hubs on the front. Wish i would of figured this out before i bought 40 dollars of dual thread lug nuts that i probably wont use with the new plan. I guess this is the whole trial and error / live and learn thing. I am just putting info out to maybe save someone else the same mistake.
Old 03-14-2013, 10:19 AM   #11
James McClure
One shot, one kill.
Re: Lug nuts?
Bojak, when I cut ( 3.5" hole saw ) mine it removed a slug just bigger than the emblem in the center of the cap leaving just under 1/8" all way round. I just went out in the garage and measured mine. 4.5" will (or should) leave you about 1/4 to 3/8" before you run into the scallops for the lug nuts. If the bolt circle is the same as other 16" wheels I think it will look just fine. jim
Old 03-14-2013, 11:49 AM   #12
bojak
bojak's Avatar
Re: Lug nuts?
What front axels are you running? Mine measure at 4 3/8 at outside edge but it does have some taper to the hub so i used "kentucky windage" and feel that 4.5 is the right hole to drill. I'm gonna do it but have my doubts about it looking as good as yours. I will post some picks when done, i picked up the 4.5 hole saw earlier so we will see.
Old 03-14-2013, 01:01 PM   #13
83GMCK2500
Re: Lug nuts?
I know you have GMT-800 wheels, but have you thought about these caps? I had an '07 with the wheels you bought, I did not care for the grooves in them, the ones that run longitudinally.
Devin
1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt
1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050
1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350
My Introduction with my '83s History
New Daily, the '96
83GMCK2500 is offline   Reply With Quote
Old 03-14-2013, 01:10 PM   #14
83GMCK2500
Re: Lug nuts?
P.S. The emblem is 3.5" diameter on those caps, and to use them on the newer alloys you have to use the black lug caps from the newer alloys.
Devin
New Daily, the '96
Old 03-14-2013, 02:43 PM   #15
bojak
bojak's Avatar
Re: Lug nuts?
These are the rims and center caps i got. This is another guy on here's truck that i got the idea from. My hurdle is the diameter of the hub on the D60. I am drilling them tonight so i will know soon enough. I hope it looks good enough to go. I really like the "it's stock, it's not" look. Little things like these wheels, all black interior parts like newer vehicles (no chromed plastic), black side molding off of 2000 style gm trucks, 2.5 inch lift. Stock but not.
Old 03-14-2013, 03:16 PM   #16
cory d
cory d's Avatar
Re: Lug nuts?
"sock but not" can be a good look. looks like it could be factory but its not
cory d is offline   Reply With Quote
Old 03-18-2013, 02:54 PM   #17
bojak
bojak's Avatar
Re: Lug nuts?
here is the update of the center caps. i stuck one on the rims i am running now just to take a photo.
Name:  wheel center caps drilled.jpg
Old 03-18-2013, 03:33 PM   #18
bojak
bojak's Avatar
Re: Lug nuts?
Here is photo of the new wheels i am going to put on. Question is should i run them how they are in light silver, or repaint them the darker pewter color that is on the older wheels? Or go black?
Name:  reba with new shoes.jpg
