03-11-2013, 04:29 PM | #1 |
LMC and 90-91 Crew cabs?
I am trying to order some parts for my new-to-me '91 GMC crew cab.
Looking and the LMC catalog, they only list to '89 for most parts, and some only to '87. Is this a qwirk with LMC, or is there something so different on a '90-91 (square body) crew that I am looking for into a black hole for parts??? I tried to call their 1-800 number, but they person (with no truck knowledge what-so-ever) gave me the canned responce of "if it isn't listed for my year, it is available". Also told me that they do not have any tech help available... For right now, I am specificly looking for fuel tank filler hoses, that go from the gas door to the tank (32-3306, 32-3307), and the turn signal lever w/cruise and w/wiper delay (34-0785). (both hoses have holes cut into them to I assume syphon the gas?)
2009 Honda Fit CfC (bsf 44.9 mpg) 2000 Tahoe Limited 1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below 1991 GMC CrewCab Dually 4x4, just going to fix things up for now 1982/1989 K5/GMC Jimmy 2wd 1987 GMC 1/2 ton swb 2wd Crew (sold) |
03-11-2013, 04:43 PM | #2 |
Re: LMC and 90-91 Crew cabs?
Dunno why it's not listed, everything is the same on these up to 91, little subtle differences, but I think those parts are the same.
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 4” SAS 1999 GMC Yukon 350/4L60 6" SAS |
03-11-2013, 05:27 PM | #3 |
I am pretty sure they are, I guess I will take a chance as I need new hoses!
03-11-2013, 06:14 PM | #4 |
LMC doesn't recognize 1tons, for some reason. the 89-91's are the same. only major difference is the front grilles on them.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205 86 k30, 89 diesel burb, 76 gmc pathfinder 71 longbed 5.3 4l80 http://67-72chevytrucks.com/vboard/s...d.php?t=522535 |
03-11-2013, 06:54 PM | #5 |
So the crews and subs/ blazers all went to 91 with square body style?? Learned something new today.Some reason I thought 89 was last year for the crews...
1977 Chev C30 454/465/14ff DRW 1974 Chev C20.350/465/14ff " Rock n Roll ain't noise pollution" |
03-11-2013, 07:22 PM | #6 |
I've been ordering parts for my year model, but, for a burb to get the CC stuff I need/want from LMC.
03-11-2013, 08:48 PM | #7 |
^^^yup, had to do that before(sub parts for crew)
only the 3/4 ton subs went to '91 Rubble, 1/2's were indep. |
03-11-2013, 08:51 PM | #8 |
the 3/4 ton subs went to '91 Rubble, the 1/2's were indep. |
03-12-2013, 12:25 AM | #9 | |
03-12-2013, 02:26 AM | #10 |
I never under stood why they don't list stuff for the in between years.GM isn't the only one ford has made 2 body styles for the same truck a year or two a few times.
03-14-2013, 02:09 AM | #11 |
thinair
You can buy that hose at Napa. It won't look factory, but they have hose for that.
Posted via Mobile Device |
03-14-2013, 08:54 AM | #12 |
Just got bit again... Ordered a new shroud + radiator cover & both were wrong....
03-14-2013, 10:35 AM | #13 |
been here longer than Liz
The fuel filler hose from LMC is generic. I had to cut to fit mine. Just go to NAPA.
~Greg~ Mac's Garage '87 SWB 6/8 drop "Piso" '08 CCSB Silverado DD the departed '89 GMC K5 Jimmy 4x4 "Rusty Nuts" '77 Chevy K5 Blazer 2wd '83 Chevy stepside "You get what you pay for" - Mike 'swervin ervin' Ervin |
03-15-2013, 10:26 PM | #14 |
I ordered the hoses and they came in today.
One is signifigantly longer than the other, I hope that is correct? Won't get a chance to take a look until tomorrow afternoon or Sunday...
03-18-2013, 02:46 AM | #15 |
So one filler hose fits correctly, the other one should be the same hose, but they list one that is about 4" long with like a 45 degree bend in it?
