53 rearend width
I know its in here somewhere but i can't find it. What is the width of the original rearend of a 53 1/2 ton. Also has anybody used a '93 chevy truck rearend?
Re: 53 rearend width
Should be 62....the 90s are too wide. A 67 68 or 69 is 6 lug and 62 1/2 and uses a 1310 joint. You have to make a catch or bracket for the cable ends and cut the old perches off and weld on new ones with a 3 degree pinion angle, but other than that its the best choice if you are staying 6 lug.
Posted via Mobile Device Last edited by NEWFISHER; 03-12-2013 at 11:46 AM. Reason: can't count |
Maybe I'm reading wrong, It is late but isn't that a 10 1/2 inch difference?
Fish just typoed....stock should be in the 62" range.
Is that measurement from flange to flange on the back plate or from the stud plate? Thanks again guys.
Mounting surface to mounting surface I recently measured mine it is def 62
Posted via Mobile Device |
oooops, edit: 62 WMS and the 67-69 is 62 1/2 WMS
Thanks again.
My neighbor's wife is a 53 and I'd guess she's about 3/4 of an axe handle across.
56 Chevy PU http://67-72chevytrucks.com/vboard/s...d.php?t=531955 Question: Know how to sell your truck for $50,000? Answer: Spend $100,000 building it. |
#10 | |
