03-11-2013, 08:58 PM | #1 |
Corvette filter/regulator
Does it make any difference where you mount the filter/regulator on the frame to keep the 58 lb. pressure at the rail? Just pick an easy to get to spot?
03-11-2013, 10:30 PM | #2 |
Re: Corvette filter/regulator
It doesn't make much difference although closer to the tank will use less hose for the return.
03-12-2013, 10:18 AM | #3 |
Boosted Member
^ This.
I've personally mounted it right next to the engine on my jet-boat, and right at the tank on a G-body. Both worked well.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2023 Ford Explorer ST - Twin Turbskis 2023 Ford F150 RCSB - Whipple Supercharged 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
03-12-2013, 10:22 AM | #4 |
Boosted Member
Also, I'd stick with a GM /ACDelco filter.
In the past with parts store brands, I've got two of them....TWO of them that have been bad out of the box. Also have a buddy that had the same problem.
03-12-2013, 12:04 PM | #5 |
Thanks for the advice. Would like to mount it on the crossmember behind the tank and then only have one line to the front, but didn't know if I would lose pressure over the longer distance. I have a Wix filter, but thanks for the info on some bad ones. That would be a quick change if you had problems.
