Old 03-11-2013, 09:56 PM   #1
ur2noz
I have engine #'s but still can't nail down exact dates. What is this thing!?
Just became a new owner to a 1970 C10. Truck has a non-original 350 in it. The engine # is V0525TBB with casting #3970010. It appears from all my research this could be a 1970 255hp 350 but could also be a late 70's 165hp 350. Clearly there is quite a difference. What other info can I look for to really hammer out a positive id? I thought maybe a compression test? Higher compression motor more then likely the high HP? Need some direction here. Also where on the trans will I find identification numbers? Its a 350 3 speed.
Appreciate everyone's help
Adam
ur2noz is offline   Reply With Quote
Old 03-11-2013, 09:58 PM   #2
Leonard1
Leonard1's Avatar
Re: I have engine #'s but still can't nail down exact dates. What is this thing!?
There will be a casting date on the bellhousing flange, usually behind the passenger side head. It should nail it down for you.
Leonard1 is offline   Reply With Quote
Old 03-11-2013, 09:58 PM   #3
bruceman1968
bruceman1968's Avatar
Get the date code off the block,
CHEVY/GMC VIN DECODERS
bruceman1968 is offline   Reply With Quote
Old 03-11-2013, 10:01 PM   #4
ur2noz
Attachment 1074680
Exactly what I was looking for. The numbers I need would be at the rear of the engine!
Old 03-12-2013, 01:05 AM   #5
oldschool18
oldschool18's Avatar
was there a vin number with the engine code on the front of the motor......on a personal note that motor was put together on my birthday.
_________________________________
62 Impala
70 C-10 LWB
71 K-10 SWB
85 C-10 LWB==SOLD
01 2500 HD
Members Met......2003Silverado (Dave)
oldschool18 is offline   Reply With Quote
Old 03-12-2013, 07:18 AM   #6
ur2noz
No vin on the block.
Old 03-12-2013, 08:54 AM   #7
TBONE1964
Cluster King
TBONE1964's Avatar
The casting number won't tell you a whole lot. 3970010 is the most common small block casting number there is. It could be a 327 with that number or like mine is a 1978 350.
The number that tells you what the engine actually was built for is the numbers stamped on the passenger deck on the front side.
I am also looking for this information for my engine.
The date code will be on the back of the block near the casting number like shown in the photo above but all that will tell you is the day/month/year the block was cast.
Just an extra note, a compression test won't help you determine compression ratio but it will tell you if the rings and valves are seating well.
TBONE1964 is offline   Reply With Quote
Old 03-12-2013, 09:54 AM   #8
cdowns
cdowns's Avatar
actually there is little to no difference bewtween a 1970 255hp and a late 70's 165hp other than slight head changes// and who's ta say that anything has not been changed in 40years
does it run? how good?
those two questions are about all that matters
if it dont run just decide// build it or crat it
Old 03-12-2013, 01:29 PM   #9
ur2noz
Truck runs fine but i enjoy knowing the details/history of my trucks. If the only difference are the heads they obviously flow quite a bit more to produce that much more horsepower.
Old 03-12-2013, 01:33 PM   #10
Crabass
Seems they would have spec'd a different cam as well.
Crabass is offline   Reply With Quote
Old 03-12-2013, 02:38 PM   #11
cdowns
cdowns's Avatar
you were not around during the 60's -70's i's guess // there was a whole lota lying an changing so in the end it was possible that what was 10hp produced a whole lotb less than 4hp of the same thing
insurance companies goverment knee jerkers news orginazations ralph the mouth nader with his witch hunts they all cause a jimbal jamble of horse power ratings and claims to where it was a joke and made it impossible to compare oranges to oranges // and going by those convolted boasts and claims of a bygone era is a wwaste of time and effort
ya wanna know go on the dyno
