Old 03-12-2013, 12:21 AM   #1
yossarian19
Fuel filler / Rollover valve / etc ??
So, I'm going to be running an LS1 pump in a Mustang tank under my '59.
I see tanks listed as being with rollover valves, and I know they are factory equipment in most cars, but I have to ask: what is it for, and do I need one?
Also - modern filler pipes come with vent lines that run between the gas cap & tank in parallel with the filler tube itself. Is this just to let air purge out as you fill the tank, or is there some other purpose I need to keep in mind?
As it is, I have a return line & a pressure line w/ filter set up & the Mustang's 45 degree 1.5" or so filler neck. No other plumbing.
What's needed?
yossarian19 is offline   Reply With Quote
Old 03-12-2013, 08:22 AM   #2
beanyard
Re: Fuel filler / Rollover valve / etc ??
I'd like to know too.
1959 Fleetside Big Window Long Box
Standard Trim soon to be Deluxe
1953 GMC Carryall Suburban
beanyard is offline   Reply With Quote
Old 03-12-2013, 10:04 AM   #3
Speedbumpauto
Speedbumpauto's Avatar
The filler neck on the Mustang tank should have a fitting for a 3/8 or so vent line that goes back to the tank. As you said, it allows air to purge when the tank is filled and with a vented cap, it allows air back in when fuel is used so a vacuum will not be created. If you can duplicate this, you don't need a rollover valve. I chose to use an aftermarket door/fill spout that had no provision for the vent to be covered by the cap so used the vent/rollover valve that came with the tank. Most newer systems use a closed system and a non vented cap in conjunction with a charcoal canister and electronic purge system to trap vapors and feed them to the engine on start up as well as vent the tank during operation. I think I posted pics of how I set up my system with the vent/rollover valve and fill door in the rear fender. Anyway, I have some if you need a look.
Speedbumpauto is offline   Reply With Quote
Old 03-12-2013, 09:01 PM   #4
yossarian19
The tank I bought has no provision for a vent pipe, it's just a plain 1.5" or so filler neck and the cam-lock for the Mustang sender.
I find an appropriate filler neck w/ internal vent pipe & run that, I suppose, with a vented cap.
Thinking about it, though - the cannister line on my Camaro fuel pump could be plumbed to a length of fuel hose connected to either a plain jane PCV valve or a small air filter, similar to what you'd see on a valve cover.... right?
