Old 03-12-2013, 06:36 AM   #1
Petie724x4
I don't mean to toot my own horn, but my truck does
It's happened a couple times, once last year, and again yesterday. When the steering wheel turns slightly to the left, horn goes off. You can hear the "clicking" of a switch at the bottom of the colum, real quick. Almost a buzz it clicks so quick. I pulled over and unplugged the horn, then took the next exit to a gas station. 15min later, problem went away.
Has this happened to anyone? Is it common? I realize I will prob have to change the whole colum, will that cure the issue?
Petie724x4 is offline   Reply With Quote
Old 03-12-2013, 06:42 AM   #2
Andy4639
Old member
Andy4639's Avatar
Talking Re: I don't mean to toot my own horn, but my truck does
The horn wire grounds to the column to complete the circuit. Look for a bad wire in the column. You may even find the disc under the horn button has shifted some and is coming into contact with the column. Check all the connections under the horn button inside the steering wheel for miss alignment.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 03-12-2013, 08:07 AM   #3
cdowns
cdowns's Avatar
yep inside the steerin column is where it is
i had one that sittin in the driveway would just start honkin in the middle of the night/// neighbors did not like my truck
Old 03-12-2013, 12:31 PM   #4
chopnchaneled
chopnchaneled's Avatar
The screw that holds the turn signal lever backed out on mine and that happened.
Is your lever a little sloppy?
I don't think we get smarter as we get older. We just run out of Stupid things to do.
chopnchaneled is offline   Reply With Quote
Old 03-12-2013, 05:13 PM   #5
Petie724x4
....not overly sloppy on the turn signal lever, but a very noisy column. Lotsa clunkin and rattlin. It is time to replace it for sure.
Thank you guys
Old 03-12-2013, 05:16 PM   #6
71K20chevy
71K20chevy's Avatar
Happened to my mom too
71 K20
64 GMC mud truck
71K20chevy is offline   Reply With Quote
Old 03-12-2013, 05:53 PM   #7
slikside
slikside's Avatar
Ditto. Mine was stripped out. Ijust put a bigger screw in it. Been a few years now.
1972 Chevy C-10, SWB, Fleet, 350/350, PS, PB, HEI, mostly stock, Survivor.
slikside is offline   Reply With Quote
Old 03-12-2013, 06:06 PM   #8
Stocker
20' Daredevil (Ret)
Stocker's Avatar
That clicking is the horn relay, mounted on the inside of the firewall near the bottom of the steering column.
Like others have said, the circuit is getting grounded near the horn button or inside the steering column. When testing or troubleshooting, just leave the horns unplugged and listen for the clicking of the relay.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
