Old 03-12-2013, 08:41 AM   #1
70inbville
wiring question
Is the factory wiring harness from a complete pull out long enough to reach inside the cab for mounting. I don't really want all of that "stuff" under to hood. I am trying not to spend 1000.00 on a painless harness if I can help it!
70inbville is offline   Reply With Quote
Old 03-12-2013, 10:33 AM   #2
Wasted Income
Boosted Member
Wasted Income's Avatar
Re: wiring question
The factory harness puts the ECM up front on the driver side. As it comes out of the donor truck, there is no way it will reach the cab. If you pull the entire harness apart, you might be able to reroute everything and reach that far...but that is a lot of work.
I personally had my ECM mounted in a nice covered bracket up on the core support. You didn't really notice it unless you were looking for it.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2023 Ford Explorer ST - Twin Turbskis
2023 Ford F150 RCSB - Whipple Supercharged
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 03-12-2013, 02:42 PM   #3
mrhurt73
Re: wiring question
i used a factory harness, and unwrapped everything and the items that would not reach were things on the drivers side of the motor, injectors, coil pack, temp sender
those things had to have wire soldered in.
was labor intensive though, not fast by any means. maybe my next one would be faster.
My Projects-
http://67-72chevytrucks.com/vboard/s...d.php?t=557301
Quest for Hot Rod Power Tour 2013.
http://67-72chevytrucks.com/vboard/s...d.php?t=543735
my 85 GMC 2wd to 4wd conversion for the wife.
mrhurt73 is offline   Reply With Quote
Old 03-12-2013, 06:07 PM   #4
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: wiring question
This depends on WHICH harness you started with. The VAN harness is longer in every way, by a decent amount, and will let you move things around easier, plus the length makes splicing easier if you need to.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 03-12-2013, 06:53 PM   #5
thotfulspot
Re: wiring question
It's not a cheap option, but Painful Wiring has an option for their harnesses to mount inside. Anybody that makes or modifies harnesses should be able to do the same thing.
thotfulspot is offline   Reply With Quote
Old 03-12-2013, 07:02 PM   #6
Crash_OK
Crash_OK's Avatar
Re: wiring question
2005 truck harness worked for me..
Mark
Crash's 69 4x4 SWB
Crash's Roof over Lake Home
Crash's 1988 Land Cruiser Build
Crash_OK is offline   Reply With Quote
Old 03-12-2013, 07:13 PM   #7
70inbville
Re: wiring question
Thanks for the info, I am a LOOONG way off just trying to do my research now!
Old 03-12-2013, 08:42 PM   #8
jorgensensc
jorgensensc's Avatar
Re: wiring question
Harness from PSI mounts it inside. Not 1000.00 and brand new quality connectors. They build the whole harness from scratch. I've heard it is a real quality piece. I'm waiting on mine to show up. Should be in the next couple of days.
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 03-13-2013, 10:58 AM   #9
70inbville
Re: wiring question
thanks for the PSI link, just what I need it looks like.
Crash, I subscribed to your build looks great!
Old 03-13-2013, 01:37 PM   #10
jorgensensc
Re: wiring question
They are great people to work with. They have great reviews all over the net, and was actually recommended to me by Brent at Dirty Dingo. Brent also builds cars for a living too. PSI took extra time to find out some info for me regarding fuel pumps and answered a bunch of questions for me weeks before I ordered. Then they tweaked the design of my harness for me as I needed it. I can't wait to get it and check it out!!
Shawn
