03-12-2013, 10:03 AM | #1 |
Suburban Hick
Differences between 216 and 235
The 47 I just picked up still has the original 216 in it and not sure how rough it is. I have access to a 235 out of a 57 1/2 ton and was thinking about putting that in the 47. At this point not really worried about originality, just more less want to make it so it can move under its own power. My main concern is will the 235 drop right in place of the 216 or do they have different motor mounts etc. Any help is appreciated. Thanks in adavance.
Mathew 1947 Chevy 3600 1951 GMC 100 1969 Chevy C-10 396/500hp TH400 lowered 4" 1968 Imapla Custom 396/325hp TH400 "Grandmas Car" 1976 Crew Cab 4x4 diesel http://67-72chevytrucks.com/vboard/s...d.php?t=488505 1978 Chevy K-10 454 1983 S10 4x4 "Bumblb" (Grandpa's truck) 1993 Chevy S10 V8 conversion 1990 Ford Probe Gt 1992 Dodge W-150 "Old Man's Truck" 1992 Pontiac Grand Prix SE 1992 Mercury Grand Marquis-Mercruiser 2000 Ford F150 (Currently my mother drives this) 1946 Farmall H with Stan Hoist loader 1965 John Deere 110 1961 Wheel Horse " Rat Tractor" |
03-12-2013, 02:14 PM | #2 |
Re: Differences between 216 and 235
Good choice to consider swaping out the 216 for a later model pressurized 235. I believe the later model TF engines have side mounts and the AD models use a front engine and bellousing mounts.
Refer to the Stovebolt forum, this was a common swap before sbc's http://www.stovebolt.com/techtips/engine_swap_216.htm |
03-12-2013, 02:57 PM | #3 |
After looking at and researching the markings on the engine in my 50 I found out that it is a 235 from a 58-62 chevy truck it was mounted in a stock configuration, I assume with the stock 50 bell housing and trans
Posted via Mobile Device |
03-12-2013, 05:07 PM | #4 |
19
56 Chevy PU http://67-72chevytrucks.com/vboard/s...d.php?t=531955 Question: Know how to sell your truck for $50,000? Answer: Spend $100,000 building it. |
03-12-2013, 07:25 PM | #5 |
Suburban Hick
Thanks for the info guys
