Old 03-12-2013, 01:12 PM   #1
jorgensensc
jorgensensc's Avatar
Glendale/ Los Angeles Can I borrow a 67-72 radiator?
Hey all,
So I'm getting frustrated with determining the electric fan thing. I have a dual electric fan setup from an 08 escalade that came with my motor for my ls swap. Timing is crucial and I would like to see if I can trim it to make it work with my 4 core radiator. Problem is I can't pull the radiator on my daily driver to find out right now. Can I borrow a stock 4 core radiator for a coiue of days roses if I can make this thing fit. If it won't work then I won't be hung up waiti g for a fan solution in the middle of my build. The radiator doesn't have to hold fluid or anything. I just need to use it for mock up purposes for the fan only. Looking for someone near Glendale or Los Angeles Ca. Thanks in advance guys!
Shawn
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 03-12-2013, 04:29 PM   #2
SS Tim
SS Tim's Avatar
Re: Glendale/ Los Angeles Can I borrow a 67-72 radiator?
Have you tried a local radiator shop? Surely someone has a core. There is also a tight so-cal group down around LA that may come to your rescue, just ask.
http://67-72chevytrucks.com/vboard/s...3&goto=newpost
SS Tim is offline   Reply With Quote
Old 03-12-2013, 06:36 PM   #3
budnikguy
budnikguy's Avatar
I have some laying around............but i am an hour east or so from LA.
budnikguy is offline   Reply With Quote
Old 03-13-2013, 01:16 AM   #4
jorgensensc
Budnik,
I going to try and find one local first, but if not I may be heading your way!
Old 03-13-2013, 01:28 AM   #5
SS Tim
SS Tim's Avatar
Near is a relative term around here. Where exactly are you needing this? A specific freeway intersection may turn up a very local contact on the board. Did you post to the SoCal I linked you to?
Old 03-14-2013, 02:03 AM   #6
jorgensensc
SS Tim,
No I haven't posted to the sight yet. Will do that tomorrow. I was hoping somebody in the glendale, Pasadena, Burbank area would pop up having an old one I could use. Even LA is reasonable enough for me. I just don't want to hunt one down at a junkyard and pay for it only to not be able to cut the fan down enough to work with the radiator.
Old 03-14-2013, 02:39 AM   #7
SS Tim
SS Tim's Avatar
Understand, that is why I wanted you to try on the "SoCal checkin' in" thread or even the "California" regional board. Like I said freeway intersections give a good idea on relative location in the LA area.
Old 03-14-2013, 09:27 AM   #8
HeloCrewChief
HeloCrewChief's Avatar
There is a 4 core one I have in storage at my fathers home in Cerritos. Let me know if your interested.
1970 C10 to K20 conversion
1974 GMC Jimmy
1968 50th Anniversary Short Bed
1968 Chevelle
1964 Comet Caliente
1990 W250 Cummins
HeloCrewChief is offline   Reply With Quote
