Old 03-12-2013, 05:35 PM   #1
1tonchevy
C35 Crew Dually
1tonchevy's Avatar
quadra jet carb
My truck has a lovely quadra squirt on it. never seems to idle,start,run properly.
Don't get me wrong she ALWAYS starts but some times it takes a while,or i have to floor it while it spits and spuders to even out.
worth the rebuild? i'm not into speed or all that so putting on a holly or edlebrock seem kinda pointless for me.... or is there OEM replacements?
If it aint square, I don't care.
84 C35 CC Dually Project log...
http://67-72chevytrucks.com/vboard/s...d.php?t=414892
1tonchevy is offline   Reply With Quote
Old 03-12-2013, 05:44 PM   #2
pwradder
pwradder's Avatar
Re: quadra jet carb
i'd stick with the q-jet if i were you then. it's definately worth trying a rebuild for the price of the kit, i've tried parts store replacement carbs and have had problems with those too.
1977 srw cc lb 396/700r/4:11's/6'' bds lift/ 35's. sold
1986 suburban 350/700r/3:73's 31's: parted out.
1980 silverado swb 5.3/700r/ 2'' drop/ daily driver. sold
1985 c10 long bed 5.3/700r/2'' drop/17" wheels/ daily driver. sold
1970 c10 long bed-new project! getting ready for the 6.0
pwradder is offline   Reply With Quote
Old 03-12-2013, 05:53 PM   #3
kcsa75
kcsa75's Avatar
Re: quadra jet carb
I recently had a quadrajet I had lying around rebuilt and you would not believe the difference. If you don't want to do it yourself or don't know someone locally, I'd reach out to Ted at Mountain Man Carburetors.
http://stores.ebay.com/Mountain-Man-...etors-Fuel-Inj
I had a couple of people recommend Ted and he did a great job for me at a fair price. He can rebuild your existing carb or sell you on that he rebuilt. Send him an email and tell him what's going on and he will suggest the best solution.
tedmtnman@yahoo.com
Good luck.
Willie
Swamp Angel Truckers
'72 C10 Highlander
People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't.
kcsa75 is offline   Reply With Quote
Old 03-12-2013, 07:08 PM   #4
88Jimmy4x4
88Jimmy4x4's Avatar
Re: quadra jet carb
Checked fuel filter yet?
2008 Silverado Z71 RCSB
1991 GMC Jimmy 4x4
1976 GMC Sierra C15 SWB
88Jimmy4x4 is offline   Reply With Quote
Old 03-12-2013, 07:41 PM   #5
hotstuff
Re: quadra jet carb
By all means rebuild the carb , your truck will love you for it ....
hotstuff is offline   Reply With Quote
Old 03-12-2013, 09:01 PM   #6
Organism_ike
Re: quadra jet carb
Don't be afraid to get in there and rebuild that qjet. It's a bit confusing at first, but once you do it your first time it'll be a cakewalk in the future. Pick up a copy of Cliff's rebuild book and check out some of his kits, otherwise I recommend quadrajetparts kits. My 305 was a whole new engine after I rebuild my quadrajet and tuned it up properly.
1983 Chevy C10 LWB
305 SBC bored .030 with cast dished pistons
Summit RV Camshaft 204/214 .424/.444
416 Iron Heads
Performer Intake, Quadrajet, and Flowtech Long Tubes
TH350 2.73 10 Bolt
Organism_ike is offline   Reply With Quote
Old 03-13-2013, 12:42 AM   #7
manimal
manimal's Avatar
Re: quadra jet carb
http://www.cliffshighperformance.com/
-Lance
2000 Chevy C2500, 5.7, 4L80e
1999 Suburban K2500, 7.4, 4L80e
1980 Camaro..son's car...PROJECT
manimal is offline   Reply With Quote
Old 03-13-2013, 08:01 AM   #8
superwade57
Re: quadra jet carb
Keep the quadra jet arguably the best, all be it complicated, designed carbs ever. I just had my brother swap the eddy 1406 off his truck and put a qj back on it. Its a mild 350. He now gets mpg instead of GPM. Lol he loves it only problem. Is it floods easily but that's cause hr needs to adjust elec. Choke.
superwade57 is offline   Reply With Quote
Old 03-14-2013, 09:36 AM   #9
billnorman
Re: quadra jet carb
Make sure the accellerator pump and choke are adjusted properly, if so, then spend the time and $$ to work on it. Easiest and cheapest thing is removing the mixture screw block offs.
billnorman is offline   Reply With Quote
Old 03-14-2013, 09:51 AM   #10
unclesalty
unclesalty's Avatar
Re: quadra jet carb
I bought Cliffs book, spent some time with it, my carb performs great now. Was well worth the time and money invested. I went with the brass float, and a different intake manifold. The factory ('69) intakes can be problematic. Also am using a phenolic resin spacer under the carb.
69 GMC 2500 custom longbed
350 4bolt,steel crank,q-jet,edelbrock streetmaster
400th
4.10 1ton floater,8 lug goodness
unclesalty is offline   Reply With Quote
Old 03-14-2013, 12:03 PM   #11
johnnyclack
Location: On the banks of the Clackamas River, Eagle CreeK Oregon
Re: quadra jet carb
Thanks for the report back, I am planning on rebuilding my QJ .....soon
johnnyclack is offline   Reply With Quote
Old 03-14-2013, 12:16 PM   #12
motornut
78K & 79C Jimmys
motornut's Avatar
Re: quadra jet carb
I'll be replaceing my 78s square bore 4BHolley to go stock QJ
and the 79s getting one too
both with performer intakes
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 03-27-2013, 07:08 PM   #13
Low_Life86
Low_Life86's Avatar
Re: quadra jet carb
i be built mine and almost **** my pants it feels like a new truck
Jeremy
'86 GMC 1500 dropped 6" in the front and 6" in the rear
2003 Land Rover Discovery
Low Life
Low_Life86 is offline   Reply With Quote
