03-12-2013, 07:30 PM | #1 |
transmission change,,,,
i have 1982 chevy c10 with 4.1 engine my transmission TH350 was cracked and made all the oil fall out,
i went to junk yard and found a TH350 1977 chevy c10 i installed it and fit with no problems, now it my truck sound rough and wont move at all, my guess is that the trans doesnt work? |
03-12-2013, 08:18 PM | #2 |
Re: transmission change,,,,
or maybe the torque converter was not installed correctly because i first screwed on the torque converter to the flywheel and then i installed the trans witch was not easy to mount the trans to the converter,
03-12-2013, 09:09 PM | #3 | |
No - that's not good. Torque convertor has to slip over the input shaft of the trans first, engaging the pump lugs. Then the whole assembly gets mounted to the engine block. Convertor bolts to flywheel after that. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
03-12-2013, 09:19 PM | #4 |
Great! Thank u very much
Posted via Mobile Device |
03-12-2013, 10:03 PM | #5 |
you more than likely killed the pumpdrive when you did that......
"DON'T TOUCH THE TRIM!!"-Early Kyler |
03-13-2013, 07:17 AM | #6 |
Make sure the convertor is all the way on as well. It should be hard to get your fingers behind it.
03-13-2013, 07:55 AM | #7 | |
At any rate, that trans has to either come back out or, at a minimum, be slid rearward to allow the convertor to be put on the input splines and engage the pump drive. Then - if he's lucky - he didn't wreck anything and it will still work. But it may be too late. K
03-13-2013, 07:58 AM | #8 | |
It should not be bound up tight. K
03-13-2013, 10:52 PM | #9 |
got it, i will check tomorrow i just bought a transmission jack.
still if the trans is bad or i messed it up i can always go pick another one in the junk yard still has warranty thanks for the help!!! |
03-14-2013, 09:23 AM | #10 |
I think you will be carting the torque converter and tranny back to the junk youd. Metal don't squeeze.
03-14-2013, 09:06 PM | #11 |
Ok so today i dropped the tranny and toque converter and i saw the torque converter wasnt all the way in
So i installed it all correctly, now the flywheel spins but truck doesnt move, drive shaft doesnt move Im taking it back to get another one, Posted via Mobile Device |
